/FAIL/MAXSTRAIN
Block Format Keyword Maximum strain failure criterion for modeling the failure of composite materials. This criterion is available for solids and shells.
/FAIL/MAXSTRAIN/mat_ID/unit_ID
ε 1 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ ε 2 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ γ 12 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdC2aa0 baaSqaaiaaigdacaaIYaaabaGaamytaiaadgeacaWGybaaaaaa@3BB4@ Ifail_sh Ifail_so
τ max MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiXdq3aaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3AB9@ Fcut
Optional Line:
fail_ID
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
ε 1 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ Longitudinal critical strain.
Default = 1020 (Real)
ε 2 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ Transverse critical strain.
γ 12 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdC2aa0 baaSqaaiaaigdacaaIYaaabaGaamytaiaadgeacaWGybaaaaaa@3BB4@ Shear critical engineering strain.
Ifail_sh Shell failure model flag.
= 0 (Default)
Shell is never deleted and no stress softening.
= 1
Shell is deleted, if damage is reached for one layer.
= 2
Shell is deleted, if damage is reached for all shell layers.
(Integer)
Ifail_so Solid failure model flag.
= 0 (Default)
Solid is never deleted and no stress softening.
= 1
Solid is deleted, if damage is reached for one integration point of solid.
= 2
Solid is deleted, if damage is reached for all integration points.
(Integer)
τ max MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiXdq3aaS baaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3AB9@ Dynamic time relaxation. 5
[ s ]
Fcut Stress tensor filtering frequency.
Default = 0.0 (Real)
[ 1 s ]
fail_ID (Optional) Failure criteria identifier.4
/UNIT/1
                  Mg                  mm                   s
/FAIL/MAXSTRN/1/1
#          EPS1_MAX             EPS2_MAX           GAM12_MAX                        IFAIL_SH  IFAIL_SO
               0.052                0.045              0.0157                                1          1
#            TAU_MAX                 FCUT
              1.0E-4                100.0ZZ
  1. This failure model is available for shells and solids. It considers a composite ply with the fibers oriented in the direction 1 (also denoted as m1) and the matrix oriented in transverse direction 2 (and 3 for solids). Each direction considers a critical strength value valid for both tension and compression:
    Where, ε 1 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ , ε 2 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aa0 baaSqaaiaaigdaaeaacaWGnbGaamyqaiaadIfaaaaaaa@3AF8@ , γ 12 M A X MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdC2aa0 baaSqaaiaaigdacaaIYaaabaGaamytaiaadgeacaWGybaaaaaa@3BB4@ are respectively the critical strain in direction 1, critical strain in direction 2 and critical engineering strain in shear.
    Note: γ 12 = 2 ε 12 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdC2aaS baaSqaaiaaigdacaaIYaaabeaakiabg2da9iaaikdacqaH1oqzdaWg aaWcbaGaaGymaiaaikdaaeqaaaaa@3E54@
    Where, ε 12 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyTdu2aaS baaSqaaiaaigdacaaIYaaabeaaaaa@393E@ is the shear strain.
  2. The failure criterion for shells is written as:
    F = max ε 1 ε 1 M A X ; ε 2 ε 2 M A X ; γ 12 γ 12 M A X 1 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9iGac2gacaGGHbGaaiiEamaabmaabaWaaSaaaeaadaabdaqaaiab ew7aLnaaBaaaleaacaaIXaaabeaaaOGaay5bSlaawIa7aaqaaiabew 7aLnaaDaaaleaacaaIXaaabaGaamytaiaadgeacaWGybaaaaaakiaa cUdadaWcaaqaamaaemaabaGaeqyTdu2aaSbaaSqaaiaaikdaaeqaaa GccaGLhWUaayjcSdaabaGaeqyTdu2aa0baaSqaaiaaikdaaeaacaWG nbGaamyqaiaadIfaaaaaaOGaai4oamaalaaabaWaaqWaaeaacqaHZo WzdaWgaaWcbaGaaGymaiaaikdaaeqaaaGccaGLhWUaayjcSdaabaGa eq4SdC2aa0baaSqaaiaaigdacaaIYaaabaGaamytaiaadgeacaWGyb aaaaaaaOGaayjkaiaawMcaaiabgsMiJkaaigdaaaa@6211@
    For solids the criterion becomes:
    F = max ε 1 ε 1 M A X ; ε 2 ε 2 M A X ; ε 3 ε 2 M A X ; γ 12 γ 12 M A X ; γ 31 γ 12 M A X 1 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9iGac2gacaGGHbGaaiiEamaabmaabaWaaSaaaeaadaabdaqaaiab ew7aLnaaBaaaleaacaaIXaaabeaaaOGaay5bSlaawIa7aaqaaiabew 7aLnaaDaaaleaacaaIXaaabaGaamytaiaadgeacaWGybaaaaaakiaa cUdadaWcaaqaamaaemaabaGaeqyTdu2aaSbaaSqaaiaaikdaaeqaaa GccaGLhWUaayjcSdaabaGaeqyTdu2aa0baaSqaaiaaikdaaeaacaWG nbGaamyqaiaadIfaaaaaaOGaai4oamaalaaabaWaaqWaaeaacqaH1o qzdaWgaaWcbaGaaG4maaqabaaakiaawEa7caGLiWoaaeaacqaH1oqz daqhaaWcbaGaaGOmaaqaaiaad2eacaWGbbGaamiwaaaaaaGccaGG7a WaaSaaaeaadaabdaqaaiabeo7aNnaaBaaaleaacaaIXaGaaGOmaaqa baaakiaawEa7caGLiWoaaeaacqaHZoWzdaqhaaWcbaGaaGymaiaaik daaeaacaWGnbGaamyqaiaadIfaaaaaaOGaai4oamaalaaabaWaaqWa aeaacqaHZoWzdaWgaaWcbaGaaG4maiaaigdaaeqaaaGccaGLhWUaay jcSdaabaGaeq4SdC2aa0baaSqaaiaaigdacaaIYaaabaGaamytaiaa dgeacaWGybaaaaaaaOGaayjkaiaawMcaaiabgsMiJkaaigdaaaa@7ABB@
    The criterion is considered to be reached when F = 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9iaaigdaaaa@3880@ . The damage variable corresponds to the criterion itself D = F MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaadAeaaaa@388E@ .
  3. Once the criterion is reached D = F = 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiraiabg2 da9iaadAeacqGH9aqpcaaIXaaaaa@3A4F@ , two behaviors can be set up:
    • If Ifail_sh = 0 or Ifail_so = 0, there is no stress softening and elements are never deleted. In this case, the failure criterion is purely visual using the output of the damage variable.
    • If Ifail_sh0 or Ifail_so0, a stress relaxation is generated to decrease the load carrying capacity of the element.
      σ ( t ) = f ( t ) σ d ( t r ) MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4WdiaacI cacaWG0bGaaiykaiabg2da9iGacAgaciGGOaGaamiDaiaacMcacqGH flY1caWHdpWaaSbaaSqaaiaadsgaaeqaaOGaaiikaiaadshadaWgaa WcbaGaamOCaaqabaGccaGGPaaaaa@4612@
      With f ( t ) = exp t t r τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaciOzaiGacIcacaWG0bGaaiykaiabg2da9iGacwgacaGG4bGaaiiC amaabmGabaGaeyOeI0YaaSaaaeaacaWG0bGaeyOeI0IaamiDamaaBa aaleaacaWGYbaabeaaaOqaaiabes8a0naaBaaaleaaciGGTbGaaiyy aiaacIhaaeqaaaaaaOGaayjkaiaawMcaaiaayIW7caaMi8oaaa@4F79@ and t t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDaiabgwMiZkaadshadaWgaaWcbaGaamOCaaqabaaaaa@3EAE@ .
      Where,
      t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDaaaa@3ACC@
      Time.
      t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaamiDamaaBaaaleaacaWGYbaabeaaaaa@3BEF@
      Start time of relaxation when the damage criteria is assumed.
      τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3E98@
      Time of dynamic relaxation.
      σ d t r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaaC4WdmaaBaaaleaacaWGKbaabeaakmaabmGabaGaamiDamaaBaaa leaacaWGYbaabeaaaOGaayjkaiaawMcaaaaa@3FF2@
      Stress tensor when the criterion is reached.
      When the stresses reach 1% of the stress value at the beginning of the failure, the element is deleted. This is necessary to avoid instabilities coming from a sudden deletion of an element and a failure “chain reaction” in the neighboring elements. Even if the failure criterion is reached, there will be no element deletion with the default value of τ max = 1.0 E 20 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaGccqGH9aqp caaIXaGaaiOlaiaaicdacaWGfbGaaGOmaiaaicdaaaa@440F@ . Therefore, it is recommended to define a value for τ max MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8akY=xipgYlh9vqqj=hEeei0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqiXdq3aaSbaaSqaaiGac2gacaGGHbGaaiiEaaqabaaaaa@3E98@ 10 times larger than the simulation time step.
  4. To avoid “chain reaction” when deleting elements, you can also define a stress tensor filtering frequency Fcut. Thus, the stress tensor used to calculate the MAXSTRAIN criterion is first to be filtered according to:
    ε n + 1 f i l t = α ε n + 1 + 1 α ε n f i l t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCyTdmaaDa aaleaacaWGUbGaey4kaSIaaGymaaqaaiaadAgacaWGPbGaamiBaiaa dshaaaGccqGH9aqpcqaHXoqycaWH1oWaaSbaaSqaaiaad6gacqGHRa WkcaaIXaaabeaakiabgUcaRmaabmaabaGaaGymaiabgkHiTiabeg7a HbGaayjkaiaawMcaaiaahw7adaqhaaWcbaGaamOBaaqaaiaadAgaca WGPbGaamiBaiaadshaaaaaaa@5040@
    With α = 2 π F c u t Δ t 2 π F c u t Δ t + 1 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdeMaey ypa0ZaaSaaaeaacaaIYaGaeqiWdaNaeyyXICTaamOramaaBaaaleaa caWGJbGaamyDaiaadshaaeqaaOGaeyyXICTaeuiLdqKaamiDaaqaai aaikdacqaHapaCcqGHflY1caWGgbWaaSbaaSqaaiaadogacaWG1bGa amiDaaqabaGccqGHflY1cqqHuoarcaWG0bGaey4kaSIaaGymaaaaaa a@54D6@
    Where, Δ t MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam iDaaaa@3853@ is the current timestep.
    If a filtering frequency is not defined (Fcut= 0.0), the filtering effect is deactivated.
  5. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
  6. The reserve/safety factor can be plotted using /H3D/ELEM/FAILURE/ID=FAILID/MODE=1. The failure index is obtained using /H3D/ELEM/FAILURE/ID=FAILID alone.
