/INISHE/SCALE_YLD or /INISH3/SCALE_YLD
Block Format Keyword This option is used to set a scale factor for yield stress per element for shells.
/INISHE/SCALE_YLD/unit_ID or /INISH3/SCALE_YLD/unit_ID | |||||||||
shell_ID | nb_integr | npg |
Repeat the next line for each integration point and each quadrature point
(nb_integr > 0, npg > 0)
Alpha_ij |
Definition
unit_ID | Optional unit
identifier. (Integer, maximum 10 digits) |
shell_ID | Element
identifier. (Integer) |
nb_integer | Integration point
number through the thickness as defined in the property
definition of this element. (Integer) |
npg | Number of surface
quadrature points.
Alpha_ij | Yield stress scale
factor of integration point. i in surface quadrature (npg) j in thickness direction (nb_integer) (Real) |
In this example use:
/PROP/SHELL Ishell =12 ≥ must set ngp=4 (then i=4 in Alpha_ij).
/PROP/SHELL
N=3 ≥ must set nb_integr=3 (then
j=3 in Alpha_ij)Figure 1.
Then the yield stress scale factor Alpha_ij is as below. And there
are totally Alpha_ij values.Figure 2.
/PROP/SHELL/2
shell prop
# Ishell Ismstr Ish3n Idrill
12 0 0 0
# hm hf hr dm dn
0 0 0 0 0
# N Thick Ashear Ithick Iplas
3 1 0 0 0
/INISHE/SCALE_YLD
# shell_ID nb_integr npg
1 3 4
# scale_yld
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
1.20
.80
1.20
#enddata
- The nb_integr must be equal to the number of integration points given in the shell property. For composite property, the number of integration corresponds to the sum of the number of integration (or slices) of each ply or layers.
- The npg must be set according to the formulation which is used in the shell property.
- The number of
values
Alpha_ij
given must be equal to
.For i = 1
- Alpha_11 for integration point = 1
- Alpha_12 for integration point = 2
- Alpha_1j for integration point = j
For i = 2- Alpha_21 for integration point = 1
- Alpha_22 for integration point = 2
- Alpha_2j for integration point =j
For i = npg- ...
- This option is available for /MAT/LAW36 and /MAT/LAW87. The card is ignored for the other materials.
