/INISHE/ORTH_LOC or /INISH3/ORTH_LOC
Block Format Keyword Describes the initialization of orthotropy direction for shells element per element.
/INISHE/ORTH_LOC/unit_ID or /INISH3/ORTH_LOC/unit_ID | |||||||||
shell_ID | nb_lay | npg | ndir | Iunit |
For each layer (integration point); except for SH_ORTH property (only one
Format):
Definition
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
shell_ID | Element
identifier. (Integer) |
nb_lay | Number of layers. Must be equal to the number of layers given in the shell property, except for /PROP/SH_ORTH (in this case nb_lay = 1). (Integer) |
npg | Number of surface
quadrature points. (Integer) |
ndir | Number of orthotropy
direction for each layer. (Integer) |
Iunit | Input angle unit flag.
(Integer) |
Angle of first direction
of orthotropy relatively of first direction of the local reference
frame. (Real) |
or if Iunit =1 | |
Angle of second direction
of orthotropy for layer i, relatively of first direction of
orthotropy. Only used for properties /PROP/TYPE16 (SH_FABR) and /PROP/TYPE51. (Real) |
or if Iunit =1 |
- This option can be used to initialize the orthotropy direction for shells element per element. By default, property defined characteristics are used, those defined using this option are priority.
- Local reference frame is described in Local Reference Frame of the Radioss Theory Manual.
- This option is compatible only with the orthotropic shell property, like /PROP/TYPE9 (SH_ORTH), /PROP/TYPE10 (SH_COMP), /PROP/TYPE11 (SH_SANDW), /PROP/TYPE16 (SH_FABR) and /PROP/TYPE51.
