/INITEMP
Block Format Keyword Describes the initial nodal temperature.
/INITEMP/initemp_ID
initemp_title
T0 grnd_ID fld_type
If fld_type =1, then:
T01 node_ID1
T02 node_ID2
T03 node_ID3
Definition
initemp_ID Initial temperature identifier.
(Integer, maximum 10 digits)
initemp_title Initial temperature name.
(Characters, maximum 100 characters)
T0 Initial temperature.
(Real)
[ K ]
grnd_ID Node group on which initial condition is applied.
(Integer)
fld_type INITEMP flag type.
= 0
Initial temperature/node group.
= 1
Initial temperature/node.
(Integer)
T01 Initial temperature.
(Real)
[ K ]
T02 Initial temperature.
(Real)
[ K ]
T03 Initial temperature.
(Real)
[ K ]
node_ID1 Node on which initial condition is applied.
(Integer)
node_ID2 Node on which initial condition is applied.
(Integer)
node_ID3 Node on which initial condition is applied.
(Integer)
  1. If fld_type = 1, temperature can be defined, both for a group of nodes (grnd_ID) and for a list of nodes (node_ID1, ... node_IDn).
  2. When fld_type = 1, if a node is both in the group of nodes (with grnd_ID), and in the node list (T01, ... T0n), the initial temperature of the group of nodes is ignored for this given node.
  3. /INITEMP is not compatible with ALE applications (/ALE, /EULER). Initial temperature will not be applied to ALE nodes or ALE elements.
