/INISHE/EPSP or /INISH3/EPSP
Block Format Keyword Describes the initial plastic strain for a shell.
| /INISHE/EPSP/unit_ID or | |||||||||
| /INISH3/EPSP/unit_ID | |||||||||
| shell_ID | p | ||||||||
Definition
| unit_ID | Unit identifier (Integer, maximum 10 digits) |
| shell_ID | Element
identifier (Integer) |
| p | Plastic
strain (Real) |
- If the shell property uses several integration points, the given plastic strain value is set to each integration point.
