New Keywords in 2025
Note: Please print this page for future reference.
New Starter Keywords
- /DFS/DETPOINT/SET - locates the detonation point defined in the node group and set lighting time for an explosive material law
- /FUNCT_PYTHON - defines a function defined with Python script
- /INISPHCEL/FULL - describes the initial state for a Smooth Particle Hydrodynamic (SPH)
- /MAT/LAW169 (ARUP_ADHESIVE) - an elastoplastic connection material law with coupled damage and failure
Modified Starter Keywords
- /CLOAD and /PLOAD - added new Itypfun flag
- /DEF_SOLID, /PROP/TYPE6 (SOL_ORTH) and /PROP/TYPE14 (SOLID) - added new element distortion control flag, Icontrol
New Engine Keywords
- /STATE/SPHCEL/FULL - describes the stress state for Smooth Particle Hydrodynamic (SPH)
New LS-DYNA Keywords
- *INITIAL_STRESS_SOLID - initializes the strain for solid elements in the global coordinate system
- *MAT_005 (SOIL_AND_FOAM) - defines an isotropic, elastic-plastic simple material model for representing soil, concrete, or crushable foam
- *MAT_073 (LOW_DENSITY_VISCOUS_FOAM) - defines a visco-elastic low density foam tabulated material for solid elements
- *MAT_111 (JOHNSON_HOLMQUIST_CONCRETE) - defines a material law that is based on the theory of Johnson-Holmquist-Cook model theory
- *MAT_183 (MAT_SIMPLIFIED_RUBBER_WITH_DAMAGE) - defines an incompressible rubber material with uniaxial tensile/compression test results as input curve
- *MAT_ADD_THERMAL_EXPANSION - used to add thermal expansion property for material
Obsolete Keywords
- All Optimization Keywords
