/INIBEAM/AUX
Block Format Keyword This option is used to initialize internal variables of user type material laws for beams (UVAR buffer).
| /INIBEAM/AUX | |||||||||
| beam_ID | nb_integr | prop_type | nvars | ||||||
For each integration point (nb_integr > 0):
| V1 | V2 | V3 | Vnvars | ||||||
Definition
| beam_ID | Element
identifier. (Integer) |
| nb_integr | Integration point
number through the section. 1 It corresponds to the property definition of this element. (Integer) |
| prop_type | Beam property set.
2 (Integer) |
| nvars | Number of auxiliary
internal variables. 3 (Integer) |
| V1 | 1st
auxiliary variable value. (Real) |
| V2 | 2nd
| V3 | 3rd
| Vnvars | nvarsth auxiliary variable
value. (Real) |
- The nb_integr must be equal to the number of integration points given in the beam property.
- /STATE/BEAM/AUX is available only for property TYPE18 (integrated beam, nb_integr > 0).
- The nvars is the number of the first user variables to be initialized for a beam. It must be less or equal to the total number of internal variables used in a user type law (NUVAR).
- The initial state for beams may be defined by more than one block.
