/INIBEAM/FULL
Block Format Keyword Describes the initial state for beam elements. All values defined in the following card will be applied at the beginning on the computation.
/INIBEAM/FULL/unit_ID
beam_ID nb_integr prop_type
EImemb EIbend
F1 F2 F3
M1 M2 M3
if nb_integr = 0 (prop_type = 3):
ε p
If nb_integr > 0 (prop_type = 18) – for each integration point:
σ 1 σ 12 σ 13 ε p
Definition
unit_ID (Optional) Unit identifier.
(Integer, maximum 10 digits)
beam_ID Element identifier.
(Integer)
nb_integr Integration point number through the section. 1
It corresponds to the property definition of this element.
(Integer)
prop_type Beam property set. 2
(Integer)
EImemb Total membrane energy.
(Real)
[ J ]
EIbend Total bending energy.
(Real)
[ J ]
F1 Beam element normal force along X direction.
(Real)
[ N ]
F2 First beam element share force (XY).
(Real)
[ N ]
F3 Second beam element share force (XZ).
(Real)
[ N ]
M1 Beam element moment around X direction.
(Real)
[ N m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@
M2 Beam element moment around Y direction.
(Real)
M3 Beam element moment around Z direction.
(Real)
σ 1 Beam normal stress.
(Real)
[ Pa ]
σ 12 First shear stress
(Real)
[ Pa ]
σ 13 Second shear stress.
(Real)
[ Pa ]
ε p Plastic strain.
(Real)
  1. The nb_integr must be equal to the number of integration points given in the beam property.
  2. If nb_integr > 0 (integrated beam – TYPE18), repeat the optional continuation lines for each integration point.
