RD-V: 0900 Perfect Gas Modeling with Polynomial EOS
The purpose of this verification problem is to plot numerical pressure, internal energy, and sound speed for a perfect gas material law.
Polynomial EOS is often used by Radioss to compute hydrodynamic pressure and used to model perfect gas. It is cubic in compression and linear in expansion.
Where,
and
A simple test of compression/expansion is made to compare these formulation outputs with theoretical results.
Options and Keywords Used
- Perfect gas
- Polynomial EOS (/EOS/POLYNOMIAL)
- Absolute / Relative formulations
- Pressure shift
- Hydrodynamic fluid material (/MAT/LAW6 (HYDRO or HYD_VISC))
- Imposed displacement (/IMPDISP)
- Lagrangian boundary conditions (/ALE/BCS)
- Nodes on each of the faces are moved with imposed displacement (/IMPDISP)
- Element pressure, density and internal energy density are saved in the Time Histories file
Input Files
Model Description
The fluid will be assumed to be a perfect gas. Volume is changed in the three directions to consider a pure compression followed by an expansion of matter (Figure 3).
This test will be modeled with a single ALE element (8 node brick) and polynomial EOS.
Evolutions of pressure, internal energy and sound speed will be compared between numerical output and theoretical results.
Simulation Iterations
A single ALE brick element is used. Material is confined inside the element by defining brick nodes as Lagrangian. For each face, displacement is imposed on the four nodes along the normal.
Polynomial EOS
Polynomial EOS is used in /EOS/POLYNOMIAL to compute hydrodynamic pressure. It is cubic in compression and linear in expansion.
- Incompressible gas
- Linear elastic material
- Perfect gas
This test is focused only on Perfect Gas modeling.
Results
Theoretical Results
- Pressure:
Perfect gas pressure is given by:
Then,
Radioss assumes the hypothesis of an isentropic process to compute the change in internal energy:
This theory gives the following differential equation:
This has the form and the general solution is:
Pressure is also polytropic:
Here, is the material constant (ratio of heat capacity). For diatomic gas =1.4. Air is made mainly of diatomic gas, so set gamma to 1.4 for air.
- Internal Energy:
Equation 5 and Equation 11 lead to the immediate result:
- Sound Speed:
Perfect gas sound speed is:
Equation 11 gives its expression in term of volume:
| Pressure (Pa) | Internal Energy Density (J) | Sound Speed (m/s) | |||
Material Control Cards
| Case | Mathematical Model | Pressure | Energy |
| 1 | absolute | absolute | |
| 2 | relative | absolute | |
| 3 | relative | relative | |
| 4 | absolute | relative |
Sound Speed and Time Step
Material LAW6 computes sound speed through the usual expression for fluids:
It can be written in function of :
Then,
The total differential of in terms of internal energy and is:
In case of an isentropic transformation (reversible and adiabatic), the change of internal energy with volume and pressure is given by:
Using relation which links and leads to:
can be expressed in terms of volume ratio:
Its variation in function of the volume change is also:
Change in internal energy per unit volume is then:
Finally, the sound speed is given by:
This expression computes the sound speed for a given equation of state . In the case of perfect gas, it was shown that for each type of formulation (absolute or relative), EOS can be written:
Equation 25 is used to compute sound speed:
| Case | C0 | C1 | C4 | C5 | c2
From Equation 25 |
Comparison with Theoretical Value |
| 1 | 0 | 0 | ||||
| 2 | 0 | 0 | ||||
| 3 | ||||||
| 4 |
For each of the four formulations, the computed sound speed by Radioss is the same as the theoretical one. Time step and cycle number are also not affected.
Case 1: Both Pressure and Energy are Absolute Values
- Pressure:
Equation of State:
Where,
Identifying the polynomial coefficients leads to:
Where,
- Corresponding
Input:
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /MAT/HYD_VISC/1 Polynomial EOS-Absolute Pressure-Absolute Energy # RHO_I RHO_0 1.204 0 # Knu Pmin 0 0 /EOS/POLYNOMIAL/1 Polynomial EOS-Absolute Pressure-Absolute Energy # C0 C1 C2 C3 0 0 0 0 # C4 C5 E0 Psh RHO_0 .4 .4 250000 0 1.204 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| - Output Results:
Table 4. Time History Measure Initial Value Unit /TH/BRICK ( ) Pressure /TH (IE) Energy /TH/BRICK (IE) Pressure - Comparison with Theoretical Result:Numerical result for perfect gas pressure is given by time history. Element time history (/TH/BRICK) allows displaying it. This result is compared to a theoretical one. Curves are superimposed.
Figure 7. Numerical Pressure, Model 1
Internal energy can be obtained through two different ways. The first one is internal energy density ( ) recorded by element time history (/TH/BRICK). The second one is the internal energy from the global time history because the model is composed of a single element.Figure 8. Numerical Internal Energy, Model 1
Case 2: Pressure is Relative and Energy is Absolute
- Pressure:
Equation of State:
Relative Pressure:
Identifying with polynomial coefficients leads to:
Where,
Minimum Pressure:
Due to , the minimum pressure must be set to a non-zero value.
- Corresponding
Input:
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /MAT/HYD_VISC/1 Polynomial EOS-Relative Pressure-Absolute Energy # RHO_I RHO_0 1.204 0 # Knu Pmin 1.5256E-5 -100000 /EOS/POLYNOMIAL/1 Polynomial EOS-Relative Pressure-Absolute Energy # C0 C1 C2 C3 0 0 0 0 # C4 C5 E0 Psh RHO_0 .4 .4 250000 100000 1.204 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| - Output Result:
Time History Measure Initial Value Unit /TH/BRICK ( ) 0 Pressure /TH (IE) Energy /TH/BRICK (IE) Pressure - Comparison with Theoretical Result:
Element time history (/TH/BRICK) is the pressure relative to Psh. The resulting curve is then shifted with Psh value and starts from 0.Figure 9. Numerical Pressure, Model 2
Internal energy can be obtained through two different ways. The first one is internal energy density ( ) recorded by element time history (/TH/BRICK). The second one is the internal energy from the global time history because the model is composed of a single element.Figure 10. Numerical Internal Energy, Model 2
Case 3: Both Pressure and Energy are Relative
- Pressure:
Equation of State:
Initial internal energy can be introduced:
Pressure from a reference one provides:
Where, .
Where, , , and .
Minimum Pressure:
- Corresponding
Input:
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /MAT/HYD_VISC/1 Polynomial EOS-Relative Pressure-Absolute Energy # RHO_I RHO_0 1.204 0 # Knu Pmin 1.5256E-5 -100000 /EOS/POLYNOMIAL/1 Polynomial EOS-Relative Pressure-Absolute Energy # C0 C1 C2 C3 100000 100000 0 0 # C4 C5 E0 Psh RHO_0 .4 .4 0 100000 1.204 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| - Output Results:
Time History Measure Initial Value Unit /TH/BRICK ( ) 0 Pressure /TH (IE) 0 Energy /TH/BRICK (IE) 0 Pressure - Comparison with Theoretical Result:
Element time history (/TH/BRICK) is the pressure relative to Psh. The resulting curve is then shifted with Psh value and starts also from 0.Figure 11. Numerical Pressure, Model 3
Internal energy can be obtained through two different ways. The first one is internal energy density ( ) recorded by element time history (/TH/BRICK). The second one is the internal energy from the global time history because the model is composed of a single element. This numerical internal energy is relative to its initial value; it is shifted with the value from the absolute theoretical one and also starts from 0.Figure 12. Numerical Internal Energy, Model 3
Case 4: Pressure is Absolute and Energy is Relative
- Pressure:
Equation of State:
Pressure from a reference provided:
Where, ;
- Corresponding
Input:
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| /MAT/HYD_VISC/1 Polynomial EOS-Relative Pressure-Absolute Energy # RHO_I RHO_0 1.204 0 # Knu Pmin 1.5256E-5 0 /EOS/POLYNOMIAL/1 Polynomial EOS-Relative Pressure-Absolute Energy # C0 C1 C2 C3 100000 100000 0 0 # C4 C5 E0 Psh RHO_0 .4 .4 0 0 1.204 #---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----| - Output Results:
Time History Measure Initial Value Unit /TH/BRICK ( ) Pressure /TH (IE) 0 Energy /TH/BRICK (IE) 0 Pressure - Comparison with Theoretical Result:Element time history (/TH/BRICK) gives absolute pressure. This result is compared to a theoretical one. Curves are superimposed.
Figure 13. Numerical Pressure, Model 4
Internal energy can be obtained through two different ways. The first one is internal energy density ( ) recorded by element time history (/TH/BRICK). The second one is the internal energy from the global time history because the model is composed of a single element. This numerical internal energy is relative to its initial value; it is shifted with the value from the absolute theoretical one and also starts from 0.Figure 14. Numerical Internal Energy, Model 4
