/EOS/POLYNOMIAL
Block Format Keyword Describes the linear polynomial equation of state P ( ρ , E ) .
/EOS/POLYNOMIAL/mat_ID/unit_ID
eos_title
C0 C1 C2 C3
C4 C5 E0 Psh
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
eos_title EOS title.
C0 Hydrodynamic pressure law coefficient.
(Real)
[ Pa ]
C1 Hydrodynamic pressure law coefficient.
(Real)
[ Pa ]
C2 Hydrodynamic pressure law coefficient.
(Real)
[ Pa ]
C3 Hydrodynamic pressure law coefficient.
(Real)
[ Pa ]
C4 Energy pressure law coefficient.
(Real)
C5 Energy pressure law coefficient.
(Real)
E0 Initial internal energy per unit reference volume.
(Real)
[ J m 3 ]
Psh Pressure shift.
(Real)
[ Pa ]
Example (Steel)
#RADIOSS STARTER
/MAT/HYD_JCOOK/8
steel
#              RHO_I               RHO_O
                7.89                  0
#                 E                   nu
                 2.1                  .3
#                  A                   B                   n              epsmax              sigmax
                .011              .00275                 .36                   0                   0
#               Pmin
               1E-10
#                  C           EPS_DOT_0                   M               Tmelt                Tmax
                .022                1E-6                   1                1811                2000
#              RHOCP                                                         T_r
             3.57E-5                                                           0
/EOS/POLYNOMIAL/8
steel
#                 C0                  C1                  C2                  C3
                   0                1.69                 3.1                   0
#                 C4                  C5                  E0                 Psh
                1.83                1.83                   0                   0
/MAT/HYD_JCOOK/9
tungstene
#              RHO_I               RHO_O
                17.6                   0
#                 E                   nu
                 3.6                  .3
              .01506              .00177                 .12                   0                   0
#               Pmin
               1E-10
                .016                1E-6                   1                3400                3400
#              RHOCP                                                         T_r
             2.36E-5                                                           0
/EOS/POLYNOMIAL/9
tungstene
#                 C0                  C1                  C2                  C3
                   0                2.82                   2               -1.37
#                 C4                  C5                  E0                 Psh
                1.54                1.54                   0                   0
#ENDDATA
  1. Pressure is defined by the linear polynomial:
    P = C 0 + C 1 μ + C 2 μ 2 + C 3 μ 3 + ( C 4 + C 5 μ ) E MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiabg2 da9iaadoeadaWgaaWcbaGaaGimaaqabaGccqGHRaWkcaWGdbWaaSba aSqaaiaaigdaaeqaaOGaeqiVd0Maey4kaSIaam4qamaaBaaaleaaca aIYaaabeaakiabeY7aTnaaCaaaleqabaGaaGOmaaaakiabgUcaRiaa doeadaWgaaWcbaGaaG4maaqabaGccqaH8oqBdaahaaWcbeqaaiaaio daaaGccqGHRaWkdaqadaqaaiaadoeadaWgaaWcbaGaaGinaaqabaGc cqGHRaWkcaWGdbWaaSbaaSqaaiaaiwdaaeqaaOGaeqiVd0gacaGLOa GaayzkaaGaamyraaaa@51AC@
    with
    μ = ρ ρ 0 − 1
    and E MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraaaa@36C0@ being the internal energy per unit reference volume.
  2. If μ < 0 , then C 2 μ 2 = 0 .
  3. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
