/EOS/SESAME
Block Format Keyword Describes the SESAME table equation of state.
| /EOS/SESAME/mat_ID/unit_ID | |||||||||
| eos_title | |||||||||
| E0 | |||||||||
| SESAME301 | |||||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| eos_title | EOS title. (Character, maximum 100 characters) |
| E0 | Initial energy per unit
reference volume. (Real) |
| SESAME301 | File name for SESAME table
#301. (Character) |
Example (Aluminum)
/EOS/SESAME/2
Aluminum 6061-T6
1. 2.700
3712_301
- unit_ID does not apply to the table which should be given in its native units: 1
Density:
Pressure:
Energy:
- The table is automatically converted in the Work Unit System, defined in the /BEGIN keyword.
- Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
1 "Handbook of Material
Properties Data Bases", Los Alamos National Laboratory, 1984.
