/MAT/LAW133 (GRANULAR)
Block Format Keyword This material law models dry granular media, such as sands, using pressure-dependent elasto-plastic formulation.
The shear modulus G ρ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGhbWaae WaaeaacqaHbpGCaiaawIcacaGLPaaaaaa@3A75@ varies with density, and the plastic yield strength Y P MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGzbWaae WaaeaacaWGqbaacaGLOaGaayzkaaaaaa@399C@ increases with pressure (hardening under confinement).
This model is typically used in combination with a compaction-type Equation of State.
/MAT/LAW133/mat_ID/unit_ID or /MAT/GRANULAR/mat_ID/unit_ID
mat_title
ρ i
nu Pmin
fct_IDG Gscale
fct_IDY Yscale
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
nu Poisson’s ratio.
(Real)
Pmin Minimum pressure.
Default = 0.0 (Real)
[ Pa ]
fct_IDG Shear modulus dependency function identifier, G ρ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGhbWaae WaaeaacqaHbpGCaiaawIcacaGLPaaaaaa@3A75@ .
= 0
G = G s c a l e MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGhbGaey ypa0Jaam4raiaadohacaWGJbGaamyyaiaadYgacaWGLbaaaa@3D9E@
> 0
G=Gscale.G ρ MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGhbGaey ypa0Jaam4raiaadohacaWGJbGaamyyaiaadYgacaWGLbGaaiOlaiaa dEeadaqadaqaaiabeg8aYbGaayjkaiaawMcaaaaa@4265@
(Integer)
Gscale Shear modulus scale factor.
Default = 1.0 (Real)
[ Pa ]
fct_IDY Yield surface dependency function identifier, Y P MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGzbWaae WaaeaacaWGqbaacaGLOaGaayzkaaaaaa@399C@ .
= 0
Y=Yscale MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGzbGaey ypa0JaamywaiaadohacaWGJbGaamyyaiaadYgacaWGLbaaaa@3DC2@
> 0
Y=Yscale.Y P MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGzbGaey ypa0JaamywaiaadohacaWGJbGaamyyaiaadYgacaWGLbGaaiOlaiaa dMfadaqadaqaaiaadcfaaiaawIcacaGLPaaaaaa@41B0@
(Integer)
Yscale Yield surface scale factor.
[ Pa ]
#RADIOSS STARTER
/UNIT/1
Unit example
                  kg                   m                   s
#-  2. MATERIALS:
/MAT/GRANULAR/1/1
Dry Sand Sjobo - Consitutive Law (LAW133)
#        Init. dens.
              1674.0
#                 nu                Pmin
                0.22                -1e3
#  G(r).id                       G-scale
       100                           1.0
#  Y(P).id                       Y-scale
       200                           1.0
/EOS/COMPACTION_TAB/1/1
Dry Sand Sjobo – Equation of State
#            RHO_TMD             C_SOLID                                                      I_PLAS
              2641.0              4634.0
# Pc(r).id                      Pc-scale
       300                           1.0
#  c(r).id                       c-scale
       400                           1.0
#  g(r).id                       g-scale
       500                           5.0
#-  3. FUNCTIONS:
/FUNCT/100
G(rho) : density-dependent shear modulus (Dry Sand Sjobo kg,m,s)
#                  X                   Y
              1674.0           0.0769E+9
              1745.6           0.8694E+9
              2086.3           4.0317E+9
              2146.8           4.9069E+9
              2300.0           7.7690E+9
              2572.0           14.801E+9
              2598.0           16.571E+9
              2635.0           36.718E+9
              2641.0           37.347E+9
              2800.0           37.347E+9
/FUNCT/200
Y(P) : pressure-dependent yield surface (Dry Sand Sjobo kg,m,s)
#                  X                   Y
                0.00                 0.0
            3.401E+6            4.235E+6
           34.898E+6           44.695E+6
           101.32E+6           124.04E+6
           184.65E+6           226.00E+6
           500.00E+6           226.00E+6
/FUNCT/300
Pc(rho) - plastic compaction curve (Dry Sand Sjobo kg,m,s)
#                  X                   Y
              1674.0                0.00
              1739.5            4.577E+6
              1873.8            14.98E+6
              1997.0           29.151E+6
              2143.8           59.175E+6
              2250.0            98.10E+6
              2380.0           179.44E+6
              2485.0           289.44E+6
              2585.0           450.20E+6
              2671.3           650.66E+6
/FUNCT/400
C_unload(rho) - elastic unloading soundspeed (Dry Sand Sjobo kg,m,s)
#                  X                   Y
              1674.0               265.2
              1745.6               852.1
              2086.3              1721.7
              2146.8              1875.5
              2300.0              2264.8
              2572.0              2956.1
              2598.0              3112.2
              2635.0              4600.0
              2641.0              4634.0
              2800.0              4634.0
/FUNCT/500
gamma(rho) - shape function for unloading path
#                  X                   Y
                1674                 1.0
                1900                 1.0
                2641                 0.0
                3000                 0.0
#enddata
/END
  1. Using this material law with /EOS/COMPACTION_TAB allows you to model the Sjöbo Dry Sand model.
  2. The Yield function Y P MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGzbWaae WaaeaacaWGqbaacaGLOaGaayzkaaaaaa@399C@ allows you to define a customized surface.
1 Leo Laine & Ola Pramm Larsen, RE-IMPLEMENTATION AND CHARACTERIZATION OF SJOBO DRY SAND IN OPENRADIOSS: IMPROVING GROUND SHOCK PREDICTIONS THROUGH TRI-AXIAL AND WAVE VELOCITY TESTING, 15th International Conference on Shock & Impact Loads on Structures 12-13 June 2025, Gothenburg, Sweden
