/EOS/EXPONENTIAL
Block Format Keyword This equation of state provides an exponential time-dependent pressure model. The pressure is defined as .
This equation of state does not have any real physical meaning. It is a model for verification and validation purposes.
/EOS/EXPONENTIALmat_ID/unit_ID | |||||||||
eos_title | |||||||||
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
eos_title | EOS title. (Character, maximum 100 characters) |
Initial
parameter. (Real) |
EOS parameter. (Real) |
Pressure
shift. (Real) |
#RADIOSS STARTER
/UNIT/1
g mm ms
/EOS/EXPONENTIAL/7/1
artificial EoS
# P0 Alpha PSH
100.0 1.0 90.0
#ENDDATA
/END
- Pressure shift is introduced as:
- As the thermodynamics for this equation of state plays no role, the speed of sound is null. Therefore, time step is 1e20. As a result, the /DTIX card should be used to impose a timestep in case only material using this equation of state is used.
