/MAT/LAW10 (DPRAG1)
Block Format Keyword This law, based on an extended Drucker-Prager yield criteria, is used to model materials with internal friction such as rock-concrete.
The yield criteria is pressure dependent. To compute the pressure an equation of
state must be provided (such as /EOS/COMPACTION). This law is
compatible only with solid elements.
Important: Starting in version
2019.1, the equation of state (EOS) parameters were removed from this material
law. Any model using the old format that includes the EOS parameters will be
converted during import into the updated material law format with an associated
/EOS/COMPACTION.
| /MAT/LAW10/mat_ID/unit_ID or /MAT/DPRAG1/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | |||||||||
| A0 | A1 | A2 | Amax | ||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| E | Young's
modulus. (Real) |
| Poisson's
ratio. (Real) |
| A0 | Yield criteria
coefficient. (Real) |
| A1 | Yield criteria
| A2 | Yield criteria
| Amax | Yield criteria limit (von
Mises limit). (Real) |
| Minimum
pressure. Default = -1030 (Real) |
Example (Concrete)
#RADIOSS STARTER
/UNIT/1
unit for mat
g cm mus
#- 2. MATERIALS:
/MAT/LAW10/1/1
Concrete
# RHO_I
2.4
# E Nu
.576 .25
# A0 A1 A2 Amax
9.72E-10 4.32E-5 .48 .013
# P_min
-1E-20
/EOS/COMPACTION/1/1
Concrete EOS
# C0 C1 C2 C3
0.0 0.256 0.256 1
# MUMIN MUMAX BUNL
0.0 0.44 0.115
# PSH RHO0
0 2.40
#ENDDATA
- Original Drucker-Prager
yield criterion has a linear pressure dependency.
Figure 1. Original Drucker-Prager Yield Criteria
Radioss is using the extended Drucker-Prager yield criteria whose pressure dependency is nonlinear.Figure 2. Extended Drucker-Prager Yield Criteria Implemented in Radioss
- Extended Drucker-Prager
yield criteria can be compared with Mohr-Coulomb criteria.
Figure 3. Extended Drucker-Prager Yield Criteria Implemented in Radioss versus Mohr-Coulomb Criteria
An extended Drucker-Prager yield criterion can be fitted from Mohr-Coulomb parameters:- Cohesion parameter
- Angle of internal friction
For this purpose, parameters must be defined as:- Modeling Type
- Parameters
- Circumscribed Drucker-Prager criteria
- Middle Circle
- Inscribed Drucker-Prager criteria
Figure 4. Fitting a Drucker-Prager Yield Criteria (blue colors) from Mohr-Coulomb Criterion (black)
- /MAT/LAW21 is also based on an extended Drucker-Prager yield criteria but pressure evolution can be described with user functions.
- Young's modulus E and Poisson’s ratio are used to determined shear modulus G which is required for sound speed calculation in solid materials.
- Starter checks the yield
parameters A0, A1, and A2 and warns you in case of an unexpected situation.
Figure 5.
