/MAT/LAW81 (DPRAG_CAP)
Block Format Keyword This law is based on Drucker-Prager pressure dependent yield criteria with an additional cap closure under high pressure loadings. It has a strain-hardening cap model based on the principles of Foster.
Plasticity is perfect unless an isotropic hardening is defined.
This law is LAG, ALE and EULER compatible.
/MAT/LAW81/mat_ID/unit_ID or /MAT/DPRAG_CAP/mat_ID/unit_ID
mat_title
ρ i
K0 G0 c0 Pb0
ϕ ψ
α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ Eps_max ε v 0 p
fct_IDK fct_IDG fct_IDC fct_IDPb Isoft
Kw n0 S0 U0
Tol α v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaadAhaaeqaaaaa@38BD@
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
K0 Initial bulk modulus.
(Real)
[ Pa ]
G0 Initial shear modulus.
(Real)
[ Pa ]
c0 Initial material cohesion.
(Real)
[ Pa ]
Pb0 Initial cap limit pressure.
(Real)
[ Pa ]
ϕ Friction angle.
(Real)
[ deg ]
ψ Plastic flow angle.
(Real)
[ deg ]
α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ Ratio of:
α = p a p b
Default = 0.5 (Real)
Eps_max Maximum dilatancy (negative number limiting ρ ρ 0 1 ).
Default = -1020 (Real)
ε v 0 p Initial value of the plastic volumetric strain. 3
(Real)
fct_IDK (Optional) Function identifier for the bulk modulus scale factor versus the plastic volumetric strain. 4
(Integer)
fct_IDG (Optional) Function identifier for the shear modulus scale factor versus the plastic volumetric strain.
(Integer)
fct_IDC (Optional) Function identifier for the material cohesion scale factor versus the equivalent plastic strain.
(Integer)
fct_IDPb (Optional) Function identifier for the cap limit pressure scale factor versus the plastic volumetric strain.
(Integer)
Isoft Cap softening flag.
= 0 (Default)
Cap softening is allowed.
= 1
Imposes that ε v p and Pb cannot decrease.
(Integer)
Kw Pore bulk modulus (water).
(Real)
[ Pa ]
n0 Initial porosity.
(Real)
S0 Initial saturation.
(Real)
U0 Initial pore pressure.
(Real)
[ Pa ]
Tol Tolerance for cap shift viscosity.
Default = 1.0E-4 (Real)
α v MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaadAhaaeqaaaaa@38BD@ Viscosity factor.
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                   m                   s
#-  2. MATERIALS:
/MAT/LAW81/1/1
LAW81
#              RHO_I
                1700
#                 K0                  G0                  c0                 PB0
              2.83E9              1.31E9                   1                   1
#                PHI                 PSI
                  15                  10
#              ALPHA           EPS_p_max               EPS_0
                  .5                 .02                .002
#  Fct_IDK   Fct_IDG   Fct_IDc  Fct_IDPb    I_soft
         0         0         3         4         1
#                 Kw                  n0                  S0                  U0
              2.5E10                 0.1                0.99                 0.0
#                Tol             alpha_v
              0.0001                 0.5
#-  3. FUNCTIONS:
/FUNCT/3
Yield Hardening
#                  X                   Y
                   0                2000
                  .1             2002000
                   1             2002000
/FUNCT/4
Cap Hardening
#                  X                   Y
                  -1                1000
                   0                1000
                .001               30000
               .0022               70000
               .0024               80000
                .004              100000
               .0056              200000
               .0078              800000
#ENDDATA
/END
  1. The yield surface is defined as:
    F = q r c ( p ) ( p tan ϕ + c ) = 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg2 da9iaadghacqGHsislciGGYbWaaSbaaSqaaiaacogaaeqaaOWaaeWa aeaacaWGWbaacaGLOaGaayzkaaGaeyyXIC9aaeWaaeaacaWGWbGaci iDaiaacggacaGGUbGaeqy1dyMaey4kaSIaam4yaaGaayjkaiaawMca aiabg2da9iaaicdaaaa@4B28@
    Where,
    p
    Hydrostatic pressure p = - 1 3 T r σ
    q
    von Mises stress q = 3 2 s : s
    c
    Material cohesion (yield stress under pure shear loading) p = 0
    ϕ
    Friction angle 0 ϕ π 2
    r c ( p ) is used to create a smooth transition between the Drucker-Prager criterion and the cap hardening, and is defined such that r c ( p ) =                             1                                                 i f                   p p a 1 ( p p a p b p a ) 2           e l s e   i f             p a p p b                             0                                     e l s e
    Where,
    pa
    Pressure triggering the yield surface to cap transition and is obtained with p a = α   p b
    pb
    Cap limit pressure.
    The yield surface thus defined is plotted in the figure below:
    mat_law81
    Note: In the figure above, a characteristic pressure denoted p 0 is emphasized. This pressure is obtained where the derivative of the yield function equals zero F p = 0 :
    p 0 = p a + - p a tan ϕ + c + p a tan ϕ + c 2 + 8 p b - p a 2 tan 2 ϕ 4 tan ϕ
  2. Plastic flow is governed by the non-associated flow potential G, as:
    G = q - p tan ψ                                                               i f                                       p p a q - tan ψ p - p - p a 2 2 p 0 - p a         e l s e   i f                     p a p p 0 F        e l s e                         p l a s t i c   f l o w   a s s o c i a t e d   o n   t h e   c a p
  3. If the two plasticity parameters p 0 and c are defined as constant p b = p b 0 and c = c 0 , the plastic response is perfect. Nevertheless, you can introduce an isotropic hardening using respectively the tabulated functions f c t _ I D P b and f c t _ I D C . The cap limit pressure will then evolve following the plastic volumetric strain (chosen as positive in compression), whereas the material cohesion will evolve following the equivalent plastic strain. In that case, the two initial parameters p b 0 and c 0 becomes scales factors:
    p b ε v p = p b 0 · f P b ε v p with ε v p = - T r ε p
    c ε e q p = c 0 · f c ε e q p with ε e q p = t = 0 t Δ ε p
  4. It is worth noting that a maximum dilatancy can be defined. In this case, the effect of the pressure on the plastic flow becomes limited to compression:
    F p = F p +   ,   G p = G p +       i f   ρ ρ 0 - 1 E p s _ m a x
  5. By default, unlike the equivalent deviatoric plastic strain ε e q p , the plastic volumetric strain ε v p can increase (in compression) or decrease (in tension) so that it may become negative. This must be considered when defining the tabulated functions using this variable. Moreover, in that case, the yield surface can harden or soften. To avoid that, you can restrict the evolution of the volumetric plastic strain to a monotonically increase using the flag I s o f t = 1 . As a result:
    ε v p = t = 0 t Δ ε v p                                           i f   I s o f t = 0 t = 0 t m a x   Δ ε v p ,   0         i f   I s o f t = 1
  6. Like the cap limit pressure p b , the bulk and shear modulus might not be constant and may vary according to the volumetric plastic strain. As described in Comment 3, their evolution can be tabulated with:
    K ε v p = K 0 · f K ε v p
    P ε v p = P 0 · f P ε v p
  7. You may want to consider that the pores of the material (concrete, soil) can be filled partially or completely with water, which can influence the mechanical behavior (especially under compressive loading). The porosity denoted n represents the volume fraction of voids with respect to the total material volume:
    n =   V v o i d V t o t a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbb a9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr 0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaape GaamOBaiabg2da9iaacckadaWcaaWdaeaapeGaamOva8aadaWgaaWc baWdbiaadAhacaWGVbGaamyAaiaadsgaa8aabeaaaOqaa8qacaWGwb WdamaaBaaaleaapeGaamiDaiaad+gacaWG0bGaamyyaiaadYgaa8aa beaaaaaaaa@445F@
    In the elastic case, the void volume does not change. However, in plasticity, the porosity change according to the volumetric plastic strain is defined by:
    n = 1 ( 1 n 0 ) e ε v p ε v 0 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa Wdbiaad6gacqGH9aqpcaaIXaGaeyOeI0YaaeWaa8aabaWdbiaaigda cqGHsislcaWGUbWdamaaBaaaleaapeGaaGimaaWdaeqaaaGcpeGaay jkaiaawMcaaiaadwgapaWaaWbaaSqabeaapeGaeqyTdu2damaaDaaa meaapeGaamODaaWdaeaapeGaamiCaaaaliabgkHiTiabew7aL9aada qhaaadbaWdbiaadAhacaaIWaaapaqaa8qacaWGWbaaaaaaaaa@4A7F@
    Where,
    n 0
    Initial porosity
    ε v 0 p
    Initial volumetric plastic strain
    When volumetric plastic strain increases, the pores of the material shrink and then the porosity decreases. The saturation in water is then higher. The saturation of pores in water corresponds to the volume fraction of water in the pores (void):
    S = V w a t e r V v o i d
    When the saturation is complete S 1 the water pressure starts to influence the compressive behavior. The pore pressure corresponds to the volumetric water pressure that is denoted u and is computed with:
    u = K w S - 1
    Where,
    K w
    Bulk water modulus
    S - 1
    Water volumetric strain, also denoted μ w
    A smooth transition is introduced to improve stability at the beginning of water pressure computation:
    • If μ w < - t o l , the water pressure equals zero,
    • If μ w t o l , u = K w 4 t o l μ w + t o l 2 ,
    • If μ w > - t o l , K w μ w .
    In addition, a viscous pressure is added when μ w > - t o l , defined as:
    u v i s = - α v K w ρ V 1 3
    The obtained pore water pressure evolution is shown below:
    Figure 2. Viscous pore water pressure evolution
    To consider the pore water pressure on the compressive mechanical behavior, the cap is shifted. The pressure then considered in the constitutive equation is substituted by a new one denoted p ' such as:
    p ' p                     i f                             p < p 0 p 0                 e l s e   i f           p - u p 0       p - u         e l s e
    The cap shift then defined is plotted in the figure below:
    Figure 3. Cap shifting introduced by pore water pressure
  8. The initial state of the pores is first defined by the initial porosity n 0 . Then, you can either specify an initial pore water pressure u 0 , or set an initial saturation S 0 :
    • If u 0 0 , the initial saturation is recomputed with:
      S 0 = 1 + u 0 K w
    • If S 0 1 , the pores are already saturated, and the initial pores water pressure is recomputed with:
      u 0 = K w S 0 - 1
    • If 0 S 0 < 1 , the initial pore water pressure is null u 0 = 0 .
  9. The following user variables are available for post-treatment:
    • USR1 is the equivalent plastic strain ε e q p
    • USR2 is the plastic volumetric strain ε v p
    • USR3 is the cohesion c
    • USR4 is the cap limit pressure pb
    • USR5 is the surface to cap pressure transition p a
    • USR6 is the null derivative criterion pressure p0
    • USR7 pore water pressure u
    • USR8 porosity n
    • USR9 saturation S
    • USR10 cap shift p'
