/DT/Eltyp/Keyword3/Iflag
Engine Keyword Element time step control.
Δ T sca Δ T min
If using /DT/BRICK/CST/1, insert the next line:
COL_min Vdef_min
If using /DT/BRICK/DEL/1, insert the next line:
COL_min Vdef_min ASP_max Vdef_max
Definition
Eltyp Entity selection:
BRICK
Brick elements
QUAD
Quad elements
SHELL
Shell elements. 8
SH_3N
Triangular shell elements
TRUSS
Truss elements
BEAM
Beam elements
SPRING
Spring elements
Keyword3 Time step control type. 1
CST
Elements are switched to small strain formulation to maintain the constant time step Δ T min . Only valid for Eltyp=BRICK or SHELL and certain values of Ismstr as defined in element properties. 5
DEL
The element which is controlling the time step is removed so that the constant time step Δ T min can be maintained.
STOP
The run will stop if the time step reaches Δ T min and a restart file will be written.
If Keyword3 is not specified, that is, /DT/Eltyp, then the default Keyword3 option for each Eltyp is used. 2
Δ T sca Scale factor on critical time step for the option defined by Eltyp.
Default = 0.9
Δ T min Minimum time step. [ s ]
Iflag Number of additional (optional) cards. Only used for /DT/BRICK/CST/1 or /DT/BRICK/DEL/1.
= 0 or blank
Only one card for Δ T sca and Δ T min is read.
= 1
An additional card for COL_min, Vdef_min, ASP_max and Vdef_max are read.
COL_min Minimum collapse ratio to switch solid element to small strain formulation (to keep constant time step) or to deleted solid element. If Ndir ≥ 1, the element is deleted and SPH elements are activated. 6 7
Default = 0
Vdef_min Minimum volume ratio (V/Vo) to switch solid element to small strain formulation (to keep constant time step) or to deleted solid element. If Ndir ≥ 1, the element is deleted and SPH elements are activated. 6 7
Default = 0
ASP_max Maximum aspect ratio to deleted solid element. If Ndir ≥ 1, the element is deleted and SPH elements are activated. 7
Used only if different from 0.
Default = 0
Vdef_max Maximum volume ratio (V/Vo) to deleted solid element. If Ndir ≥ 1, the element is deleted and SPH elements are activated. 7
Default = 0
  1. For all Keyword3 options, the time step control will be activated when the time step of the element controlling the time step of the simulation becomes less than:
    Δ T min Δ T s c a
  2. The table below lists the different available combinations of Eltyp and Keyword3. The default options are used when Keyword3 is not specified such as /DT/BRICK or /DT/SHELL.
    STOP DEL CST
    QUAD Default Optional
    BRICK Default Optional Optional
    SHELL, SH_3N Optional Default Optional
    BEAM, TRUSS, SPRING Optional Optional
  3. For each Eltyp value, only one /DT/Eltyp/Keyword3 option can be used in a simulation.
  4. /DT/Eltyp/Keyword3 can be used with /DT/NODA/Keyword3.
  5. /DT/BRICK/CST is only active when Ismstr=2 or 12 is defined in /PROP/SOLID. It is compatible with /TETRA4 with Itetra=0, /TETRA10, and /BRICK solid elements with Isolid=1, 2, 14, 17, or 24.
  6. With /DT/BRICK/CST/1, solid elements will be switched to small strain formulation when criteria for COL_min or Vdef_min is reached.
    • COL_min uses the same collapse ratio calculation as in HyperMesh element quality check.
    • Elements failing the COL_min criteria will be switched to the small strain formulation at the beginning or during a simulation.
    • Vdef_min can be used to switch highly deformed or compressed elements to the small strain formulation during the simulation thus avoiding negative volume issues that can arise.
  7. With /DT/BRICK/DEL/1, solid elements will be deleted, or switched to SPH elements if Ndir ≥ 1 in the solid property, when criteria COL_min, Vdef_min, ASP_max or Vdef_max is reached.
    • COL_min and ASP_max use the same collapse ratio and very similar aspect ratio calculation as in HyperMesh element quality check. For thickshell, thickness direction is not taken into account, then aspect ratio 2D and collapse ratio 2D (L_min/L_max) are used to compute COL_min and ASP_max.
    • Elements failing the COL_min or ASP_max criteria will be used to delete or switch to SPH elements (if Ndir ≥ 1 in the solid property) at the beginning or during a simulation.
    • Vdef_min or Vdef_max can be used to delete or switch to SPH elements (if Ndir ≥ 1 in the solid property) when the solid element is highly deformed.
  8. A more conservative and thus lower time step calculation for shell elements can be activated by using, /DT1/SHELL.
  9. A more conservative and thus lower time step calculation for solid elements can be activated by using, /DT1/BRICK.
