/DT/AIRBAG/Keyword3
Engine Keyword Time step with airbag and time step control.
/DT/AIRBAG/Keyword3
Δ T sca Δ T min
Definition
Keyword3 Time step control type:
STOP
The run will stop if the time step reaches Δ T min and a restart file will be written.
If Keyword3 is not specified, that is, /DT/AIRBAG, then the entered Δ T min is not used.
Δ T sca Scale factor on critical time step for airbag.
Default = 0.9
Δ T min Minimum time step. [ s ]
  1. /DT/AIRBAG/Keyword3 can be combined with /DT/NODA or /DT/NODA/CST.
