/DT/FVMBAG/Iflag
Engine Keyword Time step for control for Finite Volume Method airbag.
  • For Iflag = 0, 1
    /DT/FVMBAG/Iflag
    Δ T sca Δ T min
  • For Iflag = 2
    /DT/FVMBAG/Iflag
    Δ T sca Δ T min Lambda L_type
    Monvol_ID
Definition
Iflag Finite volume merge flag.
= 0 or blank (Default)
The finite volume is merged, if the time step < airbag volume < 10 * the minimum volume defined in global merge, /FVMBAG/MODIF.
= 1
The finite volume is merged, if time step < Δ T min .
= 2
The finite volume is merged, if time step < Δ T min . The time step computation is defined by the flag L_type. 2
Δ T sca Scale factor on time step.
Default = 0.9 (Real)
Δ T min Minimum time step.
(Real)
[ s ]
Lambda Stability factor.
Default = 0.01 (Real)
L_type Time step computation method.
= 1
Characteristic length of FVM mesh (computed during Starter).
= 2 (Default)
Characteristic length is computed from cubic root of the volume.
Monvol_ID Monitored volume identifier.
(Integer)
  1. The Δ T sca and Δ T min can be defined to ensure stability and a minimum time step size by triggering additional finite volume merges when the FVMBAG entity penalizes the computation.
  2. When using /DT/FVMBAG/2, time step is computed as:
    Δ T = Δ T s c a l Δ x u − w + c MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam ivaiabg2da9iabfs5aejaadsfadaWgaaWcbaGaam4CaiaadogacaWG HbGaamiBaaqabaGcdaWcaaqaaiabfs5aejaadIhaaeaadaabdaqaai aadwhacqGHsislcaWG3baacaGLhWUaayjcSdGaey4kaSIaam4yaaaa aaa@49A6@
    Where,
    u MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDaaaa@36ED@
    Gas velocity.
    w MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Daaaa@36EF@
    Polyhedron velocity.
    c MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yaaaa@36DB@
    Speed of sound.
    Δ x MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam iEaaaa@3857@
    Characteristic length.
    The soothing factor is applied using Δ T ← min Δ T , Δ T o l d 1 + λ MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeuiLdqKaam ivaiabgcziSkGac2gacaGGPbGaaiOBamaabmaabaGaeuiLdqKaamiv aiaacYcacqqHuoarcaWGubWaaSbaaSqaaiaad+gacaWGSbGaamizaa qabaGcdaqadaqaaiaaigdacqGHRaWkcqaH7oaBaiaawIcacaGLPaaa aiaawIcacaGLPaaaaaa@4B83@ .
