/PROP/PCOMPP
Block Format Keyword This property is used to define ply-based input.
| /PROP/PCOMPP/prop_ID/unit_ID | |||||||||
| prop_title | |||||||||
Definition
| prop_ID | Property
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| prop_title | Property
title. (Character, maximum 100 characters) |
- The definition of the stacking sequence of
the elements with PCOMPP property is defined through the
/STACK and /PLY option.
All elements with PCOMPP prop_ID type must belong to a ply (/PLY) inside a stack (/STACK). See Example (Substack with /DRAPE) in /STACK.
