/PLY
Block Format Keyword This option is used to define plies made of 4-node and 3-node shell elements with /PROP/PCOMPP.
| /PLY/ply_ID/unit_ID | |||||||||
| ply_title | |||||||||
| mat_ID | t | grsh4n_ID | grsh3n_ID | Npt_ply | |||||
Optional line
| drape_ID | |||||||||
Definition
| ply_ID | Ply
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| ply_title | Ply title. (Character, maximum 100 characters) |
| mat_ID | Material identifier for
ply. (Integer) |
| t | Thickness of
ply. (Real) |
| Incremental angle for
ply. (Real) |
| grsh4n_ID | Shell 4-nodes group
identifier connected to Ply. (Integer, maximum 10 digits) |
| grsh3n_ID | Shell 3-nodes group
| Npt_ply | Number of integration
points through ply thickness with, 1 ≤ Npt_ply ≤
10. Default = 1 (Integer) |
| Angle between first and
second material direction for ply
. Default = 90.0 (Real) |
| drape_ID | (Optional) Drape
identifier. 6 (Integer) |
- The ply option is used in combination with /STACK and /PROP/PCOMPP to create ply-based sandwich composite properties. See Example (Substack with /DRAPE) in /STACK.
- All elements defined in the ply must belong to a part using the /PROP/PCOMPP property. The compatibility to material law of this option is similar to /STACK.
- The ply can be attached to a group of shell element (4 or 3 node shell or both).
- If both the grsh4n_ID and the grsh3n_ID are 0, the ply is void (no element).
- The orthotropy angle is defined as follows
from the reference vector (Anisotrophy in Layer (Ply)) in the stack:Where,
- is defined per ply in stack
- is defined on the element
- is defined on the ply
- is defined in the drape table
- If drape_IDis defined, the angle of each element defined in the drape is incremented by the value defined for this element and the thickness is modified according to the thinning for this element (/DRAPE).
