/SH3N
Block Format Keyword Describes the triangular 3-node shell elements.
| /SH3N/part_ID/unit_ID | |||||||||
| tria_ID | node_ID1 | node_ID2 | node_ID3 | Thick | |||||
Definition
| part_ID | Part identifier of the
block. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| tria_ID | Element
identifier. (Integer) |
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
| node_ID3 | Node identifier
3. (Integer) |
| Orthotropy angle to
element skew. 6
(Real) |
| Thick | Shell
thickness. By default, this shell has the thickness given in the property set prop_ID of the part part_ID. (Real) |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- More than one triangular shell block can be used to define a part.
- Any number of triangular shells can be defined in one block.
- Using different numbers for 3-node and 4-node shells is recommended.
- For Coordinate system in 3-node shell element, refer to Radioss Coordinate System in the User Guide.
- The orthotropy angle is only used in /PLY and /PROP/TYPE19 (PLY).
