/STACK
Block Format Keyword Used to define the stacking sequence of a composite shell (shell belonging to a part referencing /PROP/PCOMPP) in conjunction with the /STACK option.
Two possible inputs:
  • A single stack describing the order of plies, each ply may have a different shape by associating groups of elements to the ply.
  • A sequence of substacks ("SUB"), which are comprised of several plies. The interface between substacks is defined with INT option line(s).
The input can be either "substack" or by ply, but not both.
/STACK/stack_ID/unit_ID
stack_title
Ishell Ismstr Ish3n Idrill P_thickfail Z0
hm hf hr dm dn
Ashear Iint Ithick
VX VY VZ skew_ID Iorth Ipos IP
By ply (Each ply per two lines, see Example (Substack with /DRAPE))
Pply_IDi ϕ i Zi P_thicklfail_i F_weighti
Blank
Or by substack (Each substack per two lines, see Example (Substack with /DRAPE))
Sub Nsub Sub-plyn P_thickfail_i F_weighti
Substack Name
Pply_IDi ϕ i Zi
Blank
Sub Nsub Sub-plyn
Substack Name
Pply_IDj ϕ j Zj
Blank
Optional (Each connection between 2 substacks per line)
INT Pply_IDt Pply_IDb
Definition
stack_ID Stack identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
stack_title Stack title.
Ishell Shell element formulation flag. 2
= 0
Use value in /DEF_SHELL.
= 1 Default, if /DEF_SHELL is not defined
Q4, visco-elastic hourglass modes orthogonal to deformation and rigid modes (Belytschko).
=2
Q4, visco-elastic hourglass without orthogonality (Hallquist).
= 3
Q4, elasto-plastic hourglass with orthogonality.
= 4
Q4 with improved type 1 formulation (orthogonalization for warped elements).
= 12
QBAT shell formulation
= 24
QEPH shell formulation
(Integer)
Ismstr Shell small strain formulation flag. 3
= -1
Automatically set the best value according element type and material law.
= 0
= 1
Small strain from time =0 (new formulation compatible with all other formulation flags).
= 2 Default, if /DEF_SHELL is not defined
Full geometric nonlinearities with possible small strain formulation activation in Radioss Engine (/DT/SHELL/CST).
= 4
Full geometric nonlinearities (in Radioss Engine, option /DT/SHELL/CST has no effect).
(Integer)
Ish3n 3 node shell element formulation flag.
= 0
= 1
Standard triangle (C0)
Standard triangle (C0) with modification for large rotation.
= 30
DKT18
= 31
DKT_S3, which based on DTK12 of BATOZ (refer to the Theory Manual)
(Integer)
Idrill Drilling degree of freedom stiffness flag. 7
= 0
No
= 1
Yes
(Integer)
P_thickfail Fraction of failed thickness for element deletion. 13
-1.0 ≤ P_thickfail ≤ 0
Fraction of failed integration point through thickness.
0.0 ≤ P_thickfail ≤ 1.0
Fraction of failed thickness.
Default = 1.0 (Real)
Z0 Distance from the shell to the bottom surface of the plies. 10
It should be considered, if Ipos =2.
Default = 0.0 (Real)
hr Shell membrane hourglass coefficient. 4
Default = 0.01 (Real)
hf Shell out-of-plane hourglass.
hr Shell rotation hourglass coefficient.
dm Shell membrane damping.
For additional information, refer to Hourglass Resistance in the Theory Manual.
  • Default = 5% for LAW25
  • Default = 5% for Ishell=12 (QBAT)
  • Default = 1.5% for Ishell=24 (QEPH) + LAW36 and LAW43
(Real)
dn Shell numerical damping. 5
It only used for Ishell =12 and 24
  • Default =1.5% for Ishell =24 (QEPH)
  • Default =0.1% for Ishell =12 (QBAT)
  • Default =0.01% for Ish3n =30 (DKT18)
(Real)
Ashear Shear factor.
Default is Reissner value: 5/6 (Real)
Iint Thickness integration formulation - through ply thickness. 1
= 1 (Default)
Uniform integration scheme (uniformly distribution of the integration points through ply thickness).
= 2
Gauss integration scheme.
(Integer)
Ithick Shell resultant stresses calculation flag.
= -1
= 0 (Default)
= 1
Thickness change is taken into account.
Thickness is constant.
(Integer)
VX X component for reference vector. 8
VY Y component for reference vector.
VZ Z component for reference vector.
skew_ID Skew identifier for reference vector. 8
Default = 0 (Integer)
Iorth Orthotropic system formulation flag for reference vector.
= 0 (Default)
The first axis of orthotropy is maintained at constant angle with respect to the X-axis of an orthonormal co-rotational element coordinate system.
= 1
The first orthotropy direction is constant with respect to a non-orthonormal system of deformed element.
(Integer)
Ipos Ply positioning flag for reference vector. 10
= 0 (Default)
Ply positions are automatically calculated with regard to ply thicknesses. The coherence of global thickness with the sum of ply thicknesses is automatically checked.
= 1
All ply positions in the element thickness are user-defined. Multiple plies may have the same special position. Global thickness is not checked in this case since it needs to not be equal to sum of ply thicknesses.
= 2
The bottom of the ply layout is at Z0 from the shell element mid-surface.
= 3
The top surface of the shell is considered as element reference plane.
= 4
The bottom surface of the shell is considered as element reference plane.
(Integer)
IP Reference direction in shell plane. 8
= 0 (Default)
Use 1st direction of skew_ID or vector V (if skew_ID is not defined) projected on the shell element.
= 20
Defined from element connectivity (N1,N2) of the shell element.
= 22
Defined from 1st direction of skew_ID projected on the shell element and angle phi. (Vector V is ignored).
= 23
Defined from vector product of vector V and the shell element normal direction n (skew_ID is ignored).
= 25
Defined from the azimuthal direction defined with local cylindrical coordinate system skew_ID (2nd direction) on the shell element.
= 26
Defined from 1st direction of element coordinate system.
(Integer)
Pply_IDi Ply identifier for ply i.
(Integer)
i =1, 2, 3, ...N
ϕ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHvpGzda WgaaWcbaGaaGPaVlaadMgaaeqaaaaa@3BD4@ Angle for ply i. 8
(Real)
[ deg ]
Zi, Z position of ply i (Zi or defines the position of the middle of the ply).
[ m ]
P_thicklfail_i Fraction of failed thickness for ply deletion. 13
-1.0 ≤ P_thicklfaili ≤ 0
0.0 ≤ P_thicklfaili ≤ 1.0
0.0 P _ t h i c k l f a i l _ i 1.0 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaaIWaGaai OlaiaaicdacqGHKjYOcaWGqbGaai4xaiaadshacaWGObGaamyAaiaa dogacaWGRbGaamiBamaaBaaaleaacaWGMbGaamyyaiaadMgacaWGSb Gaai4xaiaadMgaaeqaaOGaeyizImQaaGymaiaac6cacaaIWaaaaa@4C28@ (Real)
F_weighti Relative failure weight factor for layer i. 13
Sub =SUB: Indicates the beginning of a substack definition (must be left justified). 11
(Integer)
Nsub Substack identification number.
(Integer)
Sub-plyn Number of plies in substack.
(Integer)
Substack Name Name of the substack.
(Maximum 100 characters)
INT Indicates the connection between 2 substacks (must be left justified).
(Integer)
Pply_IDt Ply identification number of the top ply of the bottom substack. One of ply ID in Pply_IDi or Pply_IDj.
(Integer)
Pply_IDb Ply identification number of the bottom ply of the top substack. One of ply ID in Pply_IDi or Pply_IDj.
(Integer)
Substack definition for the ply layout with /DRAPE.
prop_type17_example
/UNIT/1
unit for mat
                  Mg                  mm                   s
/PROP/PCOMPP/1/1
PCOMPP example
/STACK/1/1
NEW_PROP_1
#   Ishell    Ismstr     Ish3n     Idril        P_thick_fail                  Z0
        12         0         0         0                   0                   0
#                 hm                  hf                  hr                  dm                  dn
                   0                   0                   0                   0                   0
#                          Ashear                Iint              Ithick
                                0                   1                   0
#                 VX                  VY                  VZ   skew_ID     Iorth      Ipos        Ip
                   0                   1                   0         0         0         0         0
#      Sub      Nsub  Sub-plyn
SUB                1         4
# Substack Name
TOP
# Pply_IDi                PHIi                  Zi     P_thickl_fail_i          F_weight_i
        11                  45                   0
        12                 -45                   0
        13                  90                   0
        14                  90                   0
#      Sub      Nsub  Sub-plyn
SUB                2         4
# Substack Name
LEFT
        21                  45                   0
        22                 -45                   0
        23                  90                   0
        24                  90                   0
#      Sub      Nsub  Sub-plyn
SUB                3         4
# Substack Name
RIGHT
        31                  45                   0
        32                 -45                   0
        33                  90                   0
        34                  90                   0
#      Sub      Nsub  Sub-plyn
SUB                4         3
# Substack Name
MIDDLE
        41                  45                   0
        42                 -45                   0
        43                  90                   0
#      Int  Pply_IDt  Pply_IDb
INT               14        21
INT               14        31
INT               43        21
INT               34        41
/PLY/11/1
Part number 11
# mat_ID_i                   t           delta_phi  grsh4n_I  grsh3n_I   Npt_ply                 A_i
         4                  .5                  45        45         0         0                   0
# drape_ID
         1
/PLY/12/1
Part number 12
         4                  .5                  45        45         0         0                   0
# drape_ID
         1
/PLY/13/1
Part number 13
         4                  .5                  45        45         0         0                   0
# drape_ID
         1
/PLY/14/1
Part number 14
         4                  .5                  45        45         0         0                   0
# drape_ID
         1
/PLY/21/1
Part number 21
         4                  .5                  45        46         0         0                   0
# drape_ID
         0
/PLY/22/1
Part number 22
         4                  .5                  45        46         0         0                   0
# drape_ID
         1
/PLY/23/1
Part number 23
         4                  .5                  45        46         0         0                   0
# drape_ID
         1
/PLY/24/1
Part number 24
         4                  .5                  45        46         0         0                   0
# drape_ID
         1
/PLY/31/1
Part number 31
         4                  .5                  45        47         0         0                   0
# drape_ID
         1
/PLY/32/1
Part number 32
         4                  .5                  45        47         0         0                   0
# drape_ID
         1
/PLY/33/1
Part number 33
         4                  .5                  45        47         0         0                   0
# drape_ID
         1
/PLY/34/1
Part number 34
         4                  .5                  45        47         0         0                   0
# drape_ID
         1
/PLY/41/1
Part number 41
         4                  .5                  45        44         0         0                   0
# drape_ID
         2
/PLY/42/1
Part number 42
         4                  .5                  45        44         0         0                   0
# drape_ID
         2
/PLY/43/1
Part number 43
         4                  .5                  45        44         0         0                   0
# drape_ID
         2
/DRAPE/1
drape in shell group 1
#   Entity Entity_ID            Thinning         Theta_drape
SHELL              2                                     45.
SHELL              3                                     45.
/DRAPE/2
drape in shell group 2
SHELL              1                                    -45.
/SHELL/3
         1     43131     43138     43137     43132                                                 0
         2     43132     43133     43136     43137                                                 0
         3     43134     43132     43137     43135                                                 0
#ENDDATA
  1. The stack is used in combination with /PLY to create composites properties through the ply-based definition. It is NOT compatible with /PROP/TYPE19 (PLY) option.
    • Each ply in the stack is defined using Pply_IDi or Pply_IDj and can only be referenced once in the stack. If ply ids are used more than once an error message will output.
    • Each ply of a shell element can contain a different (≥ 1) number of integration points through its ply thickness. That is, Npt_ply =3 in /PLY.
    • Different integration scheme (uniformly distribution or Gauss integration scheme) could be defined with option Iint inside this property,
  2. Ishell, Ish3n – 4-node and 3-node shell formulation flag.
    • Ishell =1,2,3,4 (Q4): original 4 nodes Radioss shell with hourglass perturbation stabilization.
    • Ishell =24 (QEPH): formulation with hourglass physical stabilization for general use.
    • Ishell =12 (QBAT): modified BATOZ Q4γ24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
    • Ish3n =30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points.
    • The hourglass formulation is visco-elastic for Q4 shells.
  3. Ismstr - Small strain formulation
    • Small strain formulation is activated from time t = 0, if Ismstr=1. It may be used for a faster preliminary analysis, but the accuracy of results is not ensured. Any shell for which Δ t < Δ t min can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST.
    • If Ismstr=1, the strains and stresses which are given in material laws are engineering strains and stresses; otherwise they are true strains and stresses.
  4. hm, hf, and hr - hourglass coefficients
    • hm, hf, and hr are only used for Q4 shells. They must have a value between 0 and 0.05.
    • For Ishell = 3, default values for hm and hr are 0.1.
  5. dn - Shell numerical damping
    It is only used for Ishell =12 or 24:
    • for Ishell =24, dn is used for hourglass stress calculation
    • for QBAT, dn is used for all stress terms, except transverse shear
    • for DKT18, dn is only used for membrane
  6. Ithick - Shell resultant stresses calculation flag
    • If Ithick = 1, the small strain option is automatically deactivated in the corresponding type of element
  7. Idrill - Drilling degree of freedom stiffness
    • Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems
    • Idrillis available for QEPH, QBAT (Ishell = 12, 24), and standard triangle (C0) shell elements (Ish3n = 1, 2).
  8. The orthotropy angle is defined as following from the reference vector defined in the stack:
    ϕ   =   ϕ s + ϕ i + ϕ + θ d r a p e
    Where,
    ϕ i
    is defined per ply in stack
    ϕ s
    is defined on the element
    ϕ
    is defined on the ply
    ϕ d r a p e
    is defined in the drape table
    The reference vector V MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOvaaaa@36B5@ , defined with IP, skew_ID or vector (VX, VY, VZ), is described in Composite Properties in the User Guide.
    • Example for IP = 20:
      Figure 3.
  9. The material direction definition in the initial state card (/INISHE/ORTHO, /INISH3/ORTHO) overwrites the material direction.
    In the case of reference metrics, the orientation for directions of anisotropy must be defined with the reference geometry, not the initial one.
    The 2nd material direction m2 is derived from direction m1 with the angle α i (defined in /PLY).
    If α i = 90 ° MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaadMgaaeqaaOGaeyypa0JaaGyoaiaaicdacqGHWcaSaaa@3D29@ , the layer is orthotropic.
  10. Ipos - ply position
    • In this property, ply position defined with Z i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ and option Ipos.
    • Z i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ values are real ply positions in the local Z axis (negative and positive value are allowed and Z i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ defines the position of the middle of each ply).
    • Z 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ only used with Ipos=2, it indicated distance from the shell element reference middle surface to the bottom surface of the whole ply or stack. For additional information, see Ipos=2
    • Ipos = 0: ply positions are automatically calculated with regards to ply thicknesses.
      • The input thickness “Thick” may be equal to zero as the true shell thickness is always calculated from the ply thicknesses and positions of ply defined by Z i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ .
      • If the input thickness “Thick” is different from 0.0, a warning will be displayed if the calculated thickness from the plies is different from the input thickness.
        Figure 4.
    • Ipos = 1: All ply positions and thickness in the element are user-defined (with in /PLY and Z i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ ).
      • Global thickness “Thick” is not checked, as it does not need to be equal to the sum of ply thickness
      • Multiple plies are allowed to have the same space position
      • This option is not recommended unless the number of ply is constant for all elements
        Figure 5.
    • Ipos = 2: the bottom of the ply layout is at Z 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOwamaaBa aaleaacaWGPbaabeaaaaa@37F0@ from the shell element mid-surface.
      Figure 6.
    • Ipos = 3: the top of the ply layout is coincident with the element mid-surface.
      Figure 7.
    • Ipos = 4: the bottom of the ply layout is coincident with the element mid-surface.
      Figure 8.
  11. Defined by substack.
    • If the substack definition is used, each substack definition begins with the keyword "SUB" and the substack identification number.
    • All the plies until the next keyword "SUB" or the keyword "INT" is encountered belong to the same substack.
    • All substacks must be defined before defining the “INT connections
    • If an element contains plies belonging to several substacks, the connection between the substacks is defined with an “INT” connection: the ply Pply_IDt of the first substack is connected to the ply Pply_IDb of the second substack.
    • For additional information, refer to the above examples for this property.
  12. Material for each ply.
    • Material for each ply defined with mat_ID in /PLY.
    • Different material laws could be defined for each ply.
    • The material law number given in /PART will be used to define the mass and the sound speed of the composite, as well as the interface stiffness.
  13. Element deletion rules used with P_thickfail and failure models:
    • At the ply level, all P_thicklfail_i defined in the ply and P_thickfail defined in failure model(s) (/FAIL) are considered to trigger the ply failure.
      • P_thicklfail_i > 0 defines a fraction of failed ply’s thickness. This uses the amount of ply’s thickness assigned to each thickness integration point in the ply.
      • P_thicklfail_i < 0 defines a ratio of failed ply’s integration points. This uses the number of integration point defined in the ply.
    • Minimum of the absolute value defined in the ply or in the failure criterion card is used to trigger the ply failure.
    • In case there is only 1 integration point on each ply, the P_thickfail defined in failure model(s) are not used (/PROP/TYPE17 (STACK)).
    • When plys’ failure starts, a global element deletion criterion is regarded considering the global value P_thickfail defined in the stack:
      • P_thickfail > 0 defines a fraction of failed thickness. This uses the amount of element global thickness assigned to each ply.
      • P_thickfail < 0 defines a ratio of failed plies. This uses the number of plies.
    • For fully-integrated shells (Ishell=12), the rules described above for under-integrated shells, applies to each Gauss point separately. P_thicklfail_i criterion is checked for all integration points in plys’ thickness for each in-plane Gauss point. The ply is considered as broken only when all Gauss points reach P_thicklfail_i criterion. Then global element criterion is regarded.
    • P_thickfail or P_thicklfail_i values must the same sign. Otherwise, the P_thickfail defined in the ply takes the same sign as the value defined in the failure criterion card /FAIL.
    • P_thickfail rules are not used with failure models defined inside the material laws. It is used only for the failure model defined with /FAIL.
