/TETRA10
Block Format Keyword Describes a tetrahedral solid element with 10 nodes.
| /TETRA10/part_ID | |||||||||
| tetra_ID | |||||||||
| node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 | node_ID7 | node_ID8 | node_ID9 | node_ID10 |
Definition
| part_ID | Part identifier of the
                  block. (Integer, maximum 10 digits)  |
| tetra_ID | Element
                identifier. (Integer)  |
| node_ID1 | Node identifier
                1. (Integer)  |
| node_ID2 | Node identifier
                2. (Integer)  |
| node_ID3 | Node identifier
                3. (Integer)  |
| node_ID4 | Node identifier
                4. (Integer)  |
| node_ID5 | Node identifier 5. (Integer)  |
| node_ID6 | Node identifier
                6. (Integer)  |
| node_ID7 | Node identifier
                7. (Integer)  |
| node_ID8 | Node identifier
                8. (Integer)  |
| node_ID9 | Node identifier
                9. (Integer)  |
| node_ID10 | Node identifier
                  10. (Integer) ![]()  |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
 - The part_ID of the tetrahedral 10-node elements must be different from:
- the part_ID of the brick element
 - the part_ID of the tetrahedral 4 node element
 - The values 1, 2 or 3 of the flag (Ismstr) for solid small strain formulation defined in /DEF_SOLID, are not compatible with the 10-node tetrahedral.
 - Elements may be degenerated: 4 to 9 nodes.
 - The 10 node tetrahedral elements are treated internally as solid elements (brick_ID), using solid materials and solid groups (grbric_ID).
 - When a tetra10 element is defined as a /SURF contact segment, four triangular segments are created for each tetra10 element face.
