/SHEL16
Block Format Keyword Describes the 3D shell elements (16 node thick shell elements).
This 16 node thick shell elements must be used to model thick shell structures. The element formulation is a thick shell formulation able to provide an exact description of the bending behavior (elastic and plastic) with only one element in thickness.
/SHEL16/part_ID
brick_ID node_ID1 node_ID2 node_ID3 node_ID4 node_ID5 node_ID6 node_ID7 node_ID8
node_ID9 node_ID10 node_ID11 node_ID12
node_ID13 node_ID14 node_ID15 node_ID16
Definition
part_ID Part identifier of the block.
(Integer, maximum 10 digits)
brick_ID Element identifier.
(Integer)
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
node_ID3 Node identifier 3.
(Integer)
node_ID4 Node identifier 4.
(Integer)
node_ID5 Node identifier 5.
(Integer)
node_ID6 Node identifier 6.
(Integer)
node_ID7 Node identifier 7.
(Integer)
node_ID8 Node identifier 8.
(Integer)
node_ID9 Node identifier 9.
(Integer)
node_ID10 Node identifier 10.
(Integer)
node_ID11 Node identifier 11.
(Integer)
node_ID12 Node identifier 12.
(Integer)
node_ID13 Node identifier 13.
(Integer)
node_ID14 Node identifier 14.
(Integer)
node_ID15 Node identifier 15.
(Integer)
node_ID16 Node identifier 16.
(Integer)
clip0136
  1. The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
  2. The 16 node thick shell elements are treated internally as solid elements (brick_ID); they use solid materials, and solid groups (grbric_ID).
  3. The 16 node thick shell elements should be used with the properties /PROP/TYPE20 (TSHELL) and /PROP/TYPE21 (TSH_ORTH).
  4. The 16 node thick shell elements must have a different identifier one from each other.
  5. Stress in "s" direction is not zero, but constant.
  6. If node 9 to 10 are set to zero, linear behavior is assumed on the corresponding edge.
