/PROP/TYPE15 (POROUS)
Block Format Keyword Describes the porous solid element property set (extended Darcy's law).
| /PROP/TYPE15/prop_ID or /PROP/POROUS/prop_ID | |||||||||
| prop_title | |||||||||
| Blank Format | |||||||||
| qa | qb | h | |||||||
| Por | |||||||||
| R1 | R2 | R3 | |||||||
| skew_IDr | Ihon | ||||||||
| Itu | lmix | ||||||||
| node_ID | |||||||||
Definition
| prop_ID | Property
identifier. (Integer, maximum 10 digits) |
| prop_title | Property
title. (Character, maximum 100 characters) |
| qa | Quadratic bulk
viscosity. Default = 10-20 (Real) |
| qb | Linear bulk
| h | Hourglass viscosity
coefficient. Default = 0.10 (Real) |
| Por | Porosity. Default = 1.0 (Real) |
| R1 | Specific resistance factor
in direction 1. Default = 0.0 (Real) |
| R2 | Specific resistance factor
in direction 2. Default = 0.0 (Real) |
| R3 | Specific resistance factor
in direction 3. Default = 0.0 (Real) |
| skew_IDr | Skew identifier for
resistance orthotropy. (Integer) |
| Ihon | Honeycomb substrate flag.
Default = 0.0 (Integer) |
| Itu | Turbulence imposed by
medium flag. 7
| Turbulence coefficient for
honeycomb substrate. Default = 0.1 (Real) |
| lmix | Turbulence mixing
length. (Real) |
[m] |
| node_ID | Main node identifier of
rigid body modeling rigid substrate. Default = 0 (Integer) |
Example (Air)
#RADIOSS STARTER
/PROP/POROUS/4
AIR (unit kg_m_s)
# q_a q_b h
1E-20 1E-20 0
# Por
1
# R1 R2 R3
400 400 400
# skew_IDr Ihon
0 0
# Itu alpha I_mix
0 0 0
#rbody_IDs
0
#enddata
/END
Example (Gas)
#RADIOSS STARTER
/PROP/POROUS/13
GAS (unit kg_m_s)
# q_a q_b h
1.1 .05 0
# Por
0
# R1 R2 R3
3500 0 0
# skew_IDr Ihon
3 1
# Itu alpha I_mix
1 .05 .003
#rbody_IDs
43218
#enddata
/END
- The qa and qb default values are equal to 1.10 and 0.05 in non-CFD versions.
- Porosity (relative volume of pores) is taken into account for 3D Euler materials only. Porosity is otherwise set to 1.
- is added to nodal force vector, being the tension representation of the specific resistance factor in the global skew system.
- If all resistance factors are set to 0, no computation is performed but the grid velocity can be tied to rigid body node_ID (Line 9).
- Specific resistances along orthotropic axis are defined in Line 7 with respect to skew_IDr (by default global system).
- Relevant only if material is material law 6 with turbulence.
- If Itu
=1, turbulence is imposed by porous model.
and
- Fluid reaction force vector and moment are transmitted to specified rigid body; this option is available in 3D only.
- Grid velocity is computed according to node_ID rigid body movement. This option is useful to impose such a movement to a grid, even for non-porous material.
