/PROP/TYPE14 (FLUID)
Block Format Keyword Describes the general fluid property set.
| /PROP/TYPE14/prop_ID or /PROP/FLUID/prop_ID | |||||||||
| prop_title | |||||||||
| Blank Format | |||||||||
| qa | qb | h | |||||||
Definition
| prop_ID | Property
identifier. (Integer, maximum 10 digits) |
| prop_title | Property
title. (Character, maximum 100 characters) |
| qa | Quadratic bulk
viscosity. Default = 1.10 (Real) |
| qb | Linear bulk
viscosity. Default = 0.05 (Real) |
| h | Hourglass viscosity
coefficient. Default = 0.10 (Real) |
Example (Fluid)
#RADIOSS STARTER
/PROP/FLUID/2
FLUID property
# blank card
# q_a q_b h
0 0 0
#ENDDATA
- The qa and qb default values are set to 1e-20 when option /CAA (Obsolete) is used.
- This option is compatible with all solid elements (/BRICK, /QUAD, /TRIA).
- This option is similar to /PROP/TYPE14 (SOLID), it was historically introduced to minimize the number of input parameters for CFD simulations. For ALE and EULER modeling, /PROP/SOLID (TYPE14) can be used instead.
