/MAT/LAW41 (LEE_TARVER)
Block Format Keyword This material law describes detonation products using an ignition and growth model of a reactive material.
The Lee-Tarver model is based on the assumption that the ignition starts at local hot spots in the passage of shock front and grows outward from these sites. The reaction rate is controlled by the pressure and the surface area as in a deflagration process.
/MAT/LAW41/mat_ID/unit_ID or /MAT/LEE_TARVER/mat_ID/unit_ID
mat_title
ρ i ρ 0
Ireac
A r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ B r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ R 1 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ R 2 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ R 3 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@
A p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ B p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ R 1 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ R 2 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ R 3 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@
C ν r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaDa aaleaacqaH9oGBaeaacaWGYbaaaaaa@399B@ C ν p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaDa aaleaacqaH9oGBaeaacaWGYbaaaaaa@399B@ E Q MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBa aaleaacaWGrbaabeaaaaa@37C3@
itr ε Ftol
I b x
G1 d y c
kappa khi tol
G2 e g z
a Figmax FG1max FG2min
G Ti
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
[ kg m 3 ]
ρ 0 Reference density used in E.O.S (equation of state).
Default = ρ i (Real)
[ kg m 3 ]
Ireac Ignition and growth model flag. 1
= 1 (Default)
Original 2-term-model (1980) 1
= 2
Extended 3-term-model (1985) 2
(Integer)
A r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ Reagents JWL parameter.
(Real)
[ Pa ]
B r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ Reagents JWL parameter.
(Real)
[ Pa ]
R 1 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Reagents JWL parameter.
(Real)
R 2 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Reagents JWL parameter.
(Real)
R 3 r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Reagents JWL parameter. 2
(Real)
[ J m 3 K ] = [ Pa K ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiGaccfacaGGHbaabaGaci4saaaaaiaawUfacaGLDbaaaaa@3A85@
A p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ Product JWL parameter.
(Real)
[ Pa ]
B p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyqamaaCa aaleqabaGaamOCaaaaaaa@37E1@ Product JWL parameter.
(Real)
[ Pa ]
R 1 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Product JWL parameter.
(Real)
R 2 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Product JWL parameter.
(Real)
R 3 p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaDa aaleaacaaIXaaabaGaamOCaaaaaaa@38AD@ Product JWL parameter. 2
(Real)
C ν r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaDa aaleaacqaH9oGBaeaacaWGYbaaaaaa@399B@ Volumetric heat capacity for reagents.
(Real)
C ν p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4qamaaDa aaleaacqaH9oGBaeaacaWGYbaaaaaa@399B@ Volumetric heat capacity for product.
(Real)
E Q MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyramaaBa aaleaacaWGrbaabeaaaaa@37C3@ Heat of reaction.
(Real)
[ J m 3 ]
itr Maximum number of iterations. 2
Default = 80 (Integer)
ε Convergency tolerance. 2
Default = 10-3 (Real)
Ftol Burn fraction threshold. 3
Default = 10-5 (Real)
I Lee-Tarver parameter.
(Real)
[ s 1 ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaca WGZbWaaWbaaSqabeaacqGHsislcaaIXaaaaaGccaGLBbGaayzxaaaa aa@3A9F@
b Lee-Tarver parameter.
(Real)
x Lee-Tarver parameter.
(Real)
G1 Lee-Tarver parameter.
(Real)
[ s 1 P a Z g ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaca WGZbWaaWbaaSqabeaacqGHsislcaaIXaaaaOGaaiiuaiaacggadaah aaWcbeqaaiabgkHiTiaadQfadaWgaaadbaGaam4zaaqabaaaaaGcca GLBbGaayzxaaaaaa@3F92@
d Lee-Tarver parameter.
(Real)
y Lee-Tarver parameter.
(Real)
c Lee-Tarver parameter.
(Real)
kappa Numerical limiters. 6
Default = 99.0 (Real)
khi Numerical limiters (extended model). 5
tol Numerical tolerance (extended model). 7
Default = 0.0 (Real)
G2 Lee-Tarver parameter.
(Real)
s 1 P a Z g2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaca WGZbWaaWbaaSqabeaacqGHsislcaaIXaaaaOGaaiiuaiaacggadaah aaWcbeqaaiabgkHiTiaadQfadaWgaaadbaGaam4zaiaaikdaaeqaaa aaaOGaay5waiaaw2faaaaa@404B@
e Lee-Tarver parameter.
(Real)
g Lee-Tarver parameter.
(Real)
z Lee-Tarver parameter.
(Real)
a Lee-Tarver parameter (extended model).
(Real)
Figmax Ignition term limiter (extended model). 1
(Real)
FG1max Growth term #1 limiter (extended model). 1
(Real)
FG2min Ignition term #2 limiter (extended model). 1
(Real)
G Shear modulus. 4
(Real)
[ Pa ]
Ti Initial temperature.
(Real)
[ K ]
Example (COMP-B)
#RADIOSS STARTER
#-  2. MATERIALS:
/MAT/LAW41/1
Military Comp-B (unit g,mm,µs,Mbar) ; Ref:UCRL-JC-111975,May 1993 (submittal 10th Det. Symposium)
#              RHO_0
               1.630
#    Ireac
         2
#                 Ar                  Br                 R1r                 R2r                 R3r
              1479.0            -0.05261                12.0                 1.2         2.268144E-5
#                 Ap                  Bp                 R1p                 R2p                 R3p
              5.5748              0.0783                 4.5                 1.2             0.34E-5
#                Cvr                 Cvp                  Eq
            2.487E-5                1E-5                .081
#     iter                           eps                Ftol
         0                             0                   0
#                  I                   b                   x
                44.0    0.22222222222222                   4
#                 G1                   d                   y                   c
               514.0    0.66666666666666                   2    0.22222222222222
#               kappa                 khi                 tol
                   0                   0                   0
#                 G2                   e                   g                   z
                 0.0                 0.0                 0.0                 0.0
#                  a              Figmax              FG1max              FG2min
                   0                 .30                 1.0                 1.0
#                  G                  Ti
              0.0354                 298
#ENDDATA
/END
  1. This material describes a mixture of reagents (unreacted explosive) and products (gas from detonation) for which the burn fraction is dictated by function F t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaabm aabaGaamiDaaGaayjkaiaawMcaaaaa@3940@ . There are two possible models to describe function F MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36BE@ depending on Ireac value:
    • Ireac = 1: Original 2-term-model (1980) 1
      F t = I 1F b μa x ignitionterm + G 1 1-F b F d p y growthterm MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaacq GHciITcaWGgbaabaGaeyOaIyRaamiDaaaacqGH9aqpdaqgaaqaaiaa dMeadaqadaqaaiaaigdacqGHsislcaWGgbaacaGLOaGaayzkaaWaaW baaSqabeaacaWGIbaaaOWaaeWaaeaacqaH8oqBcqGHsislcaWGHbaa caGLOaGaayzkaaWaaWbaaSqabeaacaWG4baaaaqaaiaadMgacaWGNb GaamOBaiaadMgacaWG0bGaamyAaiaad+gacaWGUbGaaGjbVlaaysW7 caWG0bGaamyzaiaadkhacaWGTbaakiaawYa7aiabgUcaRabbOpaaaa aasvgza8qadaqgaaqaaiaadEeadaWgaaWcbaGaaGymaaqabaGcdaqa daqaaiaaigdacaGGTaGaamOraaGaayjkaiaawMcaamaaCaaaleqaba GaamOyaaaakiaadAeadaahaaWcbeqaaiaadsgaaaGccaWGWbWaaWba aSqabeaacaWG5baaaaqaaiaadEgacaWGYbGaam4BaiaadEhacaWG0b GaamiAaiaaysW7caaMe8UaamiDaiaadwgacaWGYbGaamyBaaGccaGL mWoaaaa@73F1@
    • Ireac = 2: Extended 3-term-model (1985) 2
      F t = I 1 F b μ a x i g n i t i o n t e r m 0 < F < F i g max + G 1 1 - F c F d p y g r o w t h t e r m 1 0 < F < F G 1 max + G 2 1 - F e F g p z g r o w t h t e r m 2 F G 2 max < F < 1 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaacq GHciITcaWGgbaabaGaeyOaIyRaamiDaaaacqGH9aqpdaqgaaqaaiaa dMeadaqadaqaaiaaigdacqGHsislcaWGgbaacaGLOaGaayzkaaWaaW baaSqabeaacaWGIbaaaOWaaeWaaeaacqaH8oqBcqGHsislcaWGHbaa caGLOaGaayzkaaWaaWbaaSqabeaacaWG4baaaaabaeqabaGaamyAai aadEgacaWGUbGaamyAaiaadshacaWGPbGaam4Baiaad6gacaaMe8Ua amiDaiaadwgacaWGYbGaamyBaaqaaiaaicdacaaMe8UaeyipaWJaaG jbVlaadAeacaaMe8UaeyipaWJaaGjbVlaadAeadaWgaaadbaGaamyA aiaadEgaciGGTbGaaiyyaiaacIhaaeqaaaaakiaawYa7aiabgUcaRa bbOpaaaaaasvgza8qadaqgaaqaaiaadEeadaWgaaWcbaGaaGymaaqa baGcdaqadaqaaiaaigdacaGGTaGaamOraaGaayjkaiaawMcaamaaCa aaleqabaGaam4yaaaakiaadAeadaahaaWcbeqaaiaadsgaaaGccaWG WbWaaWbaaSqabeaacaWG5baaaaabaeqabaGaam4zaiaadkhacaWGVb Gaam4DaiaadshacaWGObGaaGjbVlaadshacaWGLbGaamOCaiaad2ga caaMe8UaaGymaaqaaiaaicdacaaMe8UaeyipaWJaaGjbVlaadAeaca aMe8UaeyipaWJaaGjbVlaadAeadaWgaaadbaGaam4raiaaigdaciGG TbGaaiyyaiaacIhaaeqaaaaakiaawYa7aabb6daaaaaacXwyJTgapi Gaey4kaSceeaaaaaa6dieB1vgapmWaaKbaaeaacaWGhbWaaSbaaSqa aiaaikdaaeqaaOWaaeWaaeaacaaIXaGaaiylaiaadAeaaiaawIcaca GLPaaadaahaaWcbeqaaiaadwgaaaGccaWGgbWaaWbaaSqabeaacaWG NbaaaOGaamiCamaaCaaaleqabaGaamOEaaaaaqaabeqaaiaadEgaca WGYbGaam4BaiaadEhacaWG0bGaamiAaiaaysW7caWG0bGaamyzaiaa dkhacaWGTbGaaGjbVlaaygW7caaIYaaabaGaamOramaaBaaameaaca WGhbGaaGOmaiGac2gacaGGHbGaaiiEaaqabaWccqGH8aapcaaMe8Ua amOraiaaysW7cqGH8aapcaaMe8UaaGymaaaakiaawYa7aaaa@C106@
      Where, μ = ρ / ρ 0 1 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0Maey ypa0JaeqyWdiNaai4laiabeg8aYnaaBaaaleaacaaIWaaabeaakiab gkHiTiaaigdaaaa@3F7A@ , a MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyyaaaa@36D9@ is a compression threshold under which ignition term has no contribution. Reaction rate is not computed if pressure is negative.
  2. Both reagents and products are described with a JWL equation of state. The temperature dependency form is used P ν , T = A e R 1 ν + B e R 2 ν + R 3 T / ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaabm aabaGaeqyVd4MaaiilaiaadsfaaiaawIcacaGLPaaacqGH9aqpcaWG bbGaamyzamaaCaaaleqabaGaeyOeI0IaamOuamaaBaaameaacaaIXa aabeaaliabe27aUbaakiabgUcaRiaadkeacaWGLbWaaWbaaSqabeaa cqGHsislcaWGsbWaaSbaaWqaaiaaikdaaeqaaSGaeqyVd4gaaOGaey 4kaSIaamOuamaaBaaaleaacaaIZaaabeaakiaadsfacaGGVaGaeqyV d4gaaa@5018@ where, R 3 = ω c ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaaIZaaabeaakiabg2da9iabeM8a3jaadogadaWgaaWcbaGa eqyVd4gabeaaaaa@3D5C@ .
    Consequently, a set of JWL parameters must be defined for both reagents and products:
    • Reagents:
      P r ν , T = A r e R 1 r ν + B r e R 2 r ν + R 3 r T / ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGYbaabeaakmaabmaabaGaeqyVd4Maaiilaiaadsfaaiaa wIcacaGLPaaacqGH9aqpcaWGbbWaaSbaaSqaaiaadkhaaeqaaOGaam yzamaaCaaaleqabaGaeyOeI0IaamOuamaaDaaameaadaWgaaqaaiaa igdaaeqaaaqaaiaadkhaaaWccqaH9oGBaaGccqGHRaWkcaWGcbWaaS baaSqaaiaadkhaaeqaaOGaamyzamaaCaaaleqabaGaeyOeI0IaamOu amaaDaaameaadaWgaaqaaiaaikdaaeqaaaqaaiaadkhaaaWccqaH9o GBaaGccqGHRaWkcaWGsbWaa0baaSqaamaaBaaameaacaaIZaaabeaa aSqaaiaadkhaaaGccaWGubGaai4laiabe27aUbaa@5701@
    • Products:
      P p ν , T = A p e R 1 p ν + B p e R 2 p ν + R 3 p T / ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGWbaabeaakmaabmaabaGaeqyVd4Maaiilaiaadsfaaiaa wIcacaGLPaaacqGH9aqpcaWGbbWaaSbaaSqaaiaadchaaeqaaOGaam yzamaaCaaaleqabaGaeyOeI0IaamOuamaaDaaameaadaWgaaqaaiaa igdaaeqaaaqaaiaadchaaaWccqaH9oGBaaGccqGHRaWkcaWGcbWaaS baaSqaaiaadchaaeqaaOGaamyzamaaCaaaleqabaGaeyOeI0IaamOu amaaDaaameaadaWgaaqaaiaaikdaaeqaaaqaaiaadchaaaWccqaH9o GBaaGccqGHRaWkcaWGsbWaa0baaSqaamaaBaaameaacaaIZaaabeaa aSqaaiaadchaaaGccaWGubGaai4laiabe27aUbaa@56F5@
    For reagents, B r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOqamaaBa aaleaacaWGYbaabeaaaaa@37DD@ is negative so that the solid undergoes tension and ω r MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdC3aaS baaSqaaiaadkhaaeqaaaaa@38E3@ is set to the initial Gruneisen coefficient.
    An iterative solver is used to ensure equilibrium between reagents and products: P r = P p MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuamaaBa aaleaacaWGYbaabeaakiabg2da9iaadcfadaWgaaWcbaGaamiCaaqa baaaaa@3AF1@ .
    itr is the maximum number of iteration and eps is the convergency tolerance P r P p < e p s MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaeWaaeaada abdaqaaiaadcfadaWgaaWcbaGaamOCaaqabaGccqGHsislcaWGqbWa aSbaaSqaaiaadchaaeqaaaGccaGLhWUaayjcSdGaeyipaWJaamyzai aadchacaWGZbaacaGLOaGaayzkaaaaaa@4368@ .
  3. F t o l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWG0bGaam4BaiaadYgaaeqaaaaa@39C8@ is such as:
    • F < F t o l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabgY da8iaadAeadaWgaaWcbaGaamiDaiaad+gacaWGSbaabeaaaaa@3B97@ : reaction has not started
    • F > 1 F t o l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabg6 da+iaaigdacqGHsislcaWGgbWaaSbaaSqaaiaadshacaWGVbGaamiB aaqabaaaaa@3D43@ : reaction has finished
  4. Shear modulus is used for sound speed calculation:
    c 2 = 1 ρ 0 d P d μ + 4 3 G MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yamaaCa aaleqabaGaaGOmaaaakiabg2da9maalaaabaGaaGymaaqaaiabeg8a YnaaBaaaleaacaaIWaaabeaaaaGcdaqadaqaamaalaaabaGaamizai aadcfaaeaacaWGKbGaeqiVd0gaaiabgUcaRmaalaaabaGaaGinaaqa aiaaiodaaaGaam4raaGaayjkaiaawMcaaaaa@457E@
  5. k h i MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4AaiaadI gacaWGPbaaaa@38BE@ is a numerical limiter such as:
    F t n + 1 F t n k h i MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaabm aabaGaamiDamaaBaaaleaacaWGUbGaey4kaSIaaGymaaqabaaakiaa wIcacaGLPaaacqGHsislcaWGgbWaaeWaaeaacaWG0bWaaSbaaSqaai aad6gaaeqaaaGccaGLOaGaayzkaaGaeyizImQaam4AaiaadIgacaWG Pbaaaa@45E9@
  6. k a p p a MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Aaiaadg gacaWGWbGaamiCaiaadggaaaa@3A99@ is a numerical limiter such as reaction is not calculated if Q k a p p a P MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyuaiabgw MiZkaadUgacaWGHbGaamiCaiaadchacaWGHbGaeyyXICTaamiuaaaa @4054@ .
    Where, Q MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyuaaaa@36C9@ = Pseudo viscosity (from shock front).
  7. t o l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiDaiaad+ gacaWGSbaaaa@38D1@ is a tolerance parameter.
    d F / d t MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaadA eacaGGVaGaamizaiaadshaaaa@3A3C@ is updated using F + F t o l MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraiabgU caRiaadAeadaWgaaWcbaGaamiDaiaad+gacaWGSbaabeaaaaa@3B75@ instead of F MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36BE@ in the right hand term of the 3-term-model.
  8. This material is not yet compatible with ALE.
1 Lee E.L. and Tarver C.M., "Phenomenological model of shock initiation in heterogeneous explosives" Phy. Fluids Vol. 23, No. 12, December 1980.
2 Tarver C.M., Hallquist J.O. and Erickson L.M., "Modeling Short Pulse Duration Shock Initiation of Solid Explosives", 8th International Symposium on Detonation, Albuquerque, NM, July 1985, pp 951-961
