/MAT/LAW95 (BERGSTROM_BOYCE)
Block Format Keyword This law is a constitutive model for predicting the nonlinear time dependency of elastomer like materials.
It uses a polynomial material model for the hyperelastic material response and the Bergstrom-Boyce material model 1 to represent the nonlinear viscoelastic time dependent material response. This law is only compatible with solid elements.
| /MAT/LAW95/mat_ID/unit_ID or /MAT/BERGSTROM_BOYCE/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| C10 | C01 | C20 | C11 | C02 | |||||
| C30 | C21 | C12 | C03 | sb | |||||
| D1 | D2 | D3 | Iform | ||||||
| A | C | M | Tau_ref | ||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial density. (Real) |
| C10 | Material parameter for hyperelastic
model. Default = 0.0 (Real) |
| C01 | Material parameter for hyperelastic
| C20 | Material parameter for hyperelastic
| C11 | Material parameter for hyperelastic
| C02 | Material parameter for hyperelastic
| C30 | Material parameter for hyperelastic
| C21 | Material parameter for hyperelastic
| C12 | Material parameter for hyperelastic
| C03 | Material parameter for hyperelastic
| Sb | Stress scaling factor for network B. Default = 0.0 (Real) |
| D1 | Volumetric material parameter 1, for bulk modulus computation.
| D2 | Volumetric material parameter 2. Default = 0.0 (Real) |
| D3 | Volumetric material parameter 3. Default = 0.0 (Real) |
| Poisson's ratio. Default = 0.495 (Real) |
| Iform | Volumetric formulation flag in the strain energy
potential.
(Integer) |
| A | Effective creep strain rate. Default = 0.0 (Positive Real) |
| C | Exponent characterizing the creep strain
dependence of the effective creep strain rate in
network B (-1 < C < 0). Default = -0.7 (Real) |
| M | Positive exponent (
) characterizing the
effective stress dependence of the effective creep
strain rate in network B. Default = 1.0 (Real) |
| Constant for regularization of the creep strain
rate near undeformed state. Default = 0.01 (Real) |
| Tau_ref | Reference stress for the Effective creep strain
rate in secondary network. Default = 1.0 (Real) |
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/LAW95/1/1
BERGSTROM
# RHO_I
1.42E-6
# C10 C01 C20 C11 C22
0.2019 0. 4.43E-5
# C30 C21 C12 C03 Sb
1.295E-4 0. 0. 0. 2.0
# D1 D2 D3 NU iform
2.1839E-3 8.68E-5 -1.794E-5 0. 1
# A EXPC EXPM KSI Tau_ref
1.0E-1 -0.7 5 0.01
#ENDDATA
- The response of the material can be
represented using two parallel networks A and B.
Network A is the equilibrium network with a
nonlinear hyperelastic component. In network B, a
nonlinear hyperelastic component is in series with
a nonlinear viscoelastic flow element, and hence
the time-dependent network.
Figure 1. Time-dependent Network
- The same polynomial strain energy
potential is used for the hyperelastic components
in both networks. In network B, this potential is
scaled by factor
Sb.
The strain energy density of the hyperelastic
component of the network can have 2 different
forms for the volumetric part depending on the
flag Iform:
- Iform = 1
(Default):
- Iform =
2:Where,
- Iform = 1
(Default):
- For special value of
, the polynomial model
can be reduced to the following material
models:
- Yeoh: j=0
Where, C10, C20, C30 are not zero
- Mooney-Rivlin: i+j =1
Where, C10 and C01 are not zero, and D2 =D3=0
- Neo-Hookean:
Only C10 and D1 are not zero
- Yeoh: j=0
- The initial shear modulus and the bulk
modulus are computed as:
and
- If D1= 0, an incompressible material is considered.
- If =0, then only the hyperelastic polynomial material model is used with no viscoelastic time dependent response.
- The effective creep strain rate in
network
is given by the
expression:Where,
- and
- Effective stress in Network B
- , , and
- Input material parameters
