/MAT/LAW62 (VISC_HYP)
Block Format Keyword This law describes the hyper visco-elastic material. This law is compatible with solid and shell elements. In general it is used to model polymers and elastomers.
| /MAT/LAW62/mat_ID/unit_ID or /MAT/VISC_HYP/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| N | M | Flag_Visc | Form | ||||||
Definition
| mat_ID | Material
identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material
title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| Equivalent Poisson's
ratio. Default = 0.0 (Real) |
| N | Law order - must be
positive. (Integer) |
| M | Maxwell model order.
(Integer) |
| Maximum
viscosity. Default = 1030 (Real) |
| Flag_Visc | Viscous formulation flag,
used if M > 0.
| Form | Initial visco-elastic
modulus formulation used, if M >
0.
(Integer) |
| ith parameter of the ground shear
modulus. (Real) |
| ith material
parameter. (Real) |
| ith stiffness
ratio. (Real) |
| ith time
relaxation. (Real) |
| ith Poisson’s ratio. Used only if
one of the ith Poisson’s ratio is
greater than 0. (Real) |
Example (Hyper-elastic Rubber)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW62/1/1
LAW62 RUBBER 1
# RHO_I
1E-9
# Nu N M mu_max Flag_Visc Form
.495 2 0 0 1 0
# mu_i
2 1
# alpha_i
2 -2
# nu_i
.495 .4
/MAT/LAW62/2/1
LAW62 RUBBER 2
# RHO_I
1E-9
.495 2 2 0 1 0
# mu_i
2 1
# alpha_i
2 -2
# gamma_i
.2 .3
# tetha_i
.007 .05
# nu_i
0 0
#ENDDATA
/END
- Strain energy
W is computed using the following
equation:With
- are eigenvalue of F (F is deformation gradient matrix),
- J is Jacobian determinant, with ,
- N is the order of law,
and
are the material
parameters:
is the Poisson's ratio with
If are 0 or not defined, equivalent Poison’s ratio is used, instead.
If are defined, the equivalent Poison’s ratio is recomputed according to the shear and bulk modulus.
- Coefficients (
) are used to describe rate effects through the
Maxwell model:
The initial shear modulus is:
The sum of should be greater than 0.
The stiffness ratio is:
With,
and
is the ground shear modulusThe relaxation time, must be positive:
- Rate effects are modeled using a convolution integral using Prony series. This is an extension of small strain theory to large strain. Strain rate effect applies only to the deviatoric stress. The full expression of the deviatoric viscous stress can be found in the Radioss Theory Manual.
- There are several differences between /MAT/LAW42 (OGDEN) and /MAT/LAW62. Special care should be taken that the ground shear modulus expression is not the same depending on input values. Furthermore, in one case it corresponds to the long-term shear modulus, whereas in another case it corresponds to the initial shear modulus.
