/VISC/PRONY
Block Format Keyword This is an isotropic visco-elastic Maxwell model that can be used to add visco-elasticity to certain shell and solid element material models. The visco-elasticity is input using a Prony series.
| /VISC/PRONY/mat_ID/unit_ID | |||||||||
| M | Itab | Ishape | |||||||
| Ifunc_G | XGscale | YGscale | |||||||
| Ifunc_K | XKscale | YKscale | |||||||
| Ifunc_Gs | XGs_scale | YGs_scale | |||||||
| Ifunc_Gl | XGl_scale | YGl_scale | |||||||
| Ifunc_Ks | XKs_scale | YKs_scale | |||||||
| Ifunc_Kl | XKl_scale | YKl_scale | |||||||
Definition
| mat_ID | Material identifier which
refers to the viscosity card. (Integer, maximum 10 digits) |
| unit_ID | Unit identifier. (Integer, maximum 10 digits) |
| M | Maxwell model order
(number of Prony coefficients). Default = 0 (Integer) |
| Viscous bulk modulus.
3 Only used if
. Default = 0. (Real) |
| Itab | Tabulated formulation flag.
(Integer) |
| Ishape | Tabulated Prony series
shape flag (Only if Itab ≠0).
(Integer) |
| Shear relaxation modulus
for ith term
(i=1,
M). (Real) |
| Decay shear constant for
ith term
(i=1,
M). (Real) |
| Bulk relaxation modulus
for ith term
(i=1, M). 3 (Real) |
| Decay bulk constant for
ith term
(i=1,
M). (Real) |
| Ifunc_G | Relaxation test data curve
for shear modulus. (Integer) |
| XGscale | Time scale factor for
shear modulus relaxation test data curve. Default = 1.0 (Real) |
| YGscale | Scale factor for shear
| Ifunc_K | Relaxation test data curve
for bulk modulus. (Integer) |
| XKscale | Time scale factor for bulk
| YKscale | Scale factor for bulk
| Ifunc_Gs | Shear storage modulus data
curve. (Integer) |
| XGs_scale | Frequency scale factor for
shear storage modulus test data curve. Default = 1.0 (Real) |
| YGs_Scale | Scale factor for shear
| Ifunc_Gl | Shear loss modulus data
curve. (Integer) |
| XGl_scale | Frequency scale factor for
shear loss modulus test data curve. Default = 1.0 (Real) |
| YGl_Scale | Scale factor for shear
| Ifunc_Ks | Bulk storage modulus data
curve. (Integer) |
| XKs_scale | Frequency scale factor for
bulk storage modulus test data curve. Default = 1.0 (Real) |
| YKs_scale | Scale factor for bulk
| Ifunc_Kl | Bulk loss modulus data
curve. (Integer) |
| XKl_scale | Frequency scale factor for
bulk loss modulus test data curve. Default = 1.0 (Real) |
| YKl_scale | Scale factor for bulk loss
- For shell elements this model is
available with /MAT/LAW66 and
/MAT/LAW25 (COMPSH).
For solid elements it is available with material laws /MAT/LAW38 (VISC_TAB), /MAT/LAW42 (OGDEN), /MAT/LAW69, /MAT/LAW70 (FOAM_TAB), /MAT/LAW82, /MAT/LAW88, /MAT/LAW90, /MAT/LAW92, /MAT/LAW95 (BERGSTROM_BOYCE), /MAT/LAW103 (HENSEL-SPITTEL), /MAT/LAW106 (JCOOK_ALM), and /MAT/LAW126 (JOHNSON_HOLMQUIST_CONCRETE).
- The viscosity effect is taken into
account by using a Prony series. The deviatoric viscous stress is given by the
convolution integral of the form:
with
and denotes the deviatoric part of strain tensor.
Shear decay:
Where, is the relaxation time.
- For the viscous pressure, two formulations are
available:
- If the bulk relaxation modulus is
, the viscous pressure is computed
as:
with and
and the viscous bulk modulus
as:
as:
- Starting with Radioss version 2017, identical results are obtained using the same Prony coefficients Gi in /VISC/PRONY and visco-elastic materials /MAT/LAW34 (BOLTZMAN), /MAT/LAW40 (KELVINMAX), and /MAT/LAW42 (OGDEN). In previous Radioss versions, 2 Gi had to be input into /VISC/PRONY to get equivalent results.
- Prony series parameters can be
automatically fit from test data using the flag Itab:
- If Itab =
1, Prony series parameters are fitted from
relaxation tests data, that is, moduli versus time curves.
Figure 1. Example of Prony series fitting on shear modulus relaxation test data
- If Itab =
2, Prony series parameters are fitted from Dynamic
Mechanical Analysis (DMA) tests data, that is, storage and loss moduli
versus frequency curves.
Figure 2. Example of Prony series fitting on shear storage and loss modulus DMA test data. data taken from [Tapia-Romero et al.,2020]
Note: The convergence of the least square fit may be hard to achieve for very high orders. - If Itab =
- The shape of the fitted Prony
series (only in case where Itab ≠ 0) can be
chosen by you:
- If Ishape =
0, the shape of the fitted Prony series are the
same as the one given above, so as:
and
- If Ishape =
1, the shape of the fitted Prony series is modified
to consider the infinite values of the moduli, so as:
and
Note: In this case, the infinite value of the moduli is taken as the last value of the relaxation test data curve if Itab = 1, or the first storage modulus value if Itab = 2. - If Ishape =
