/MAT/LAW15 (CHANG)
Block Format Keyword This law is used to model composite shell elements, similar to LAW25. The plastic behavior is based on the Tsai-Wu criteria (/MAT/LAW25 (COMPSH) for Tsai-Wu description) and failure is based on the Chang-Chang failure criterion is used.
It is recommended to use material LAW25 in combination with a separate Chang-Chang failure criteria (/MAT/LAW25 with /FAIL/CHANG keywords), instead of material LAW15.
/MAT/LAW15/mat_ID/unit_ID or /MAT/CHANG/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E11 | E22 | ||||||||
G12 | G23 | G31 | |||||||
b | n | fmax | |||||||
Ioff | |||||||||
c | ICC | ||||||||
S1 | S2 | S12 | |||||||
Fsmooth | Fcut | C1 | C2 |
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
mat_title | Material
title. (Character, maximum 100 characters) |
Initial
density. (Real) |
E11 | Young's modulus in
direction 1. (Real) |
E22 | Young's modulus in
direction 2. (Real) |
Poisson's
ratio. (Real) |
G12 | Shear
modulus. (Real) |
G23 | Shear
modulus. (Real) |
G311 | Shear
modulus. (Real) |
b | Hardening
parameter. (Real) |
n | Hardening
exponent. Default = 1.0 (Real) |
fmax | Maximum value of yield
function. 2 Default = 1030 (Real) |
Maximum plastic energy per
volume unit. Default = 1030 (Real) |
Reference plastic energy
per volume unit. Default = 1.0 (Real) |
Ioff | Total element failure
criteria. 4
(Integer) |
Composite yield stress in
tension in direction 1. 2 (Real) |
tension in direction 2. (Real) |
compression in direction 1. (Real) |
compression in direction 2. (Real) |
F12
reduction factor. 2 Default set to 1.0 (Real) |
Yield stress in shear and
strain rate compression in direction 12. (Real) |
strain rate tension in direction 12. (Real) |
c | Yield stress in shear and
strain rate coefficient. 2
(Real) |
strain rate reference. (Real) |
ICC | Strain rate computation
flag. 2
(Integer) |
Shear scaling factor.
1 (Real) |
Time relaxation. 3 Default = 1030 (Real) |
S1 | Longitudinal tensile
strength. 1 Default = 1030 (Real) |
S2 | Transverse tensile
strength. Default = 1030 (Real) |
S12 | Shear strength. Default = 1030 (Real) |
Fsmooth | Smooth strain rate option flag.
(Integer) |
Fcut | Cutoff frequency for
strain rate filtering. Default = 1030 (Real) |
C1 | Longitudinal compressive
C2 | Transverse compressive
Example (Carbon)
#RADIOSS STARTER
/UNIT/1
unit for mat
kg mm ms
#- 2. MATERIALS:
/MAT/LAW15/1/1
Carbon
# RHO_I
1.8E-6 0
# E11 E22 nu12
41 3.3 .3
# G12 G23 G31
5.2 1.3 1.3
# b n fmax
8E-6 1 100000
# Wpmax Wpref Ioff
100000 0 0
# sigma_1yt sigma_2yt sigma_1yc sigma_2yc alpha
.786 .1566 .786 .1566 0
# sigma_12yc sigma_12yt c Eps_dot_0 ICC
.0655 .0655 0 0 0
# beta Tmax S1 S2 S12
1 .01 0 0 0
# Fsmooth Fcut C1 C12
0 0 0 0
#ENDDATA
/END
- Chang-Chang failure criteriaSix material parameters are used in the Chang-Chang failure criteria to describe the two different failure behaviors.
- For fiber breakage, the failure criteria is:
- Tensile fiber mode
- Compressive fiber mode
- For matrix cracking, the failure criteria is:
- Compressive matrix mode
- Before failed (damage parameter is less than 0), material is in elastic–plastic phase. The plastic behavior is based on the TSAI-WU criteria (see Tsai-Wu Formulation (Iform =0) for Tsai-Wu criterion description).
- After failed (damage parameter
is greater than or equal to 0), the stresses are
decreased by using an exponential function to avoid numerical instabilities.
A relaxation technique is used by gradually decreasing the stress.
With function of relaxation:
and
Where,- Time
- Start time of relaxation when the damage criteria is assumed
- Time of dynamic relaxation
- Stress components at the beginning of damage
- If a shell has several layers with one material per layer (different materials, different Ioff), the Ioff used is the one which is associated to the shell in the shell element definition.
