Lamina yield surface defined by Tsai-Wu yield criteria is used for each
layer:
with:
=1,2,3);
Where,
is the yield stress in direction
and
denote respectively for compression and tension.
represents the yield envelope evolution during work hardening
with respect to strain rate effects:
Where,
- Plastic work
- Hardening parameter
- Hardening exponent
- Strain rate coefficient
is limited by a maximum value
If the maximum value is reached the material is failed.
In
Equation 5, the strain rate
effects on the evolution of yield envelope. However, it is also possible to take into
account the strain rate
effects on the maximum stress
as shown in
Table 1.
Table 1. Strain Rate Dependency
| (a) Strain
rate effect on
(b) No strain
rate effect on
