Elastic-plastic Orthotropic Composite Shells
- Composite shells with isotropic layers
- Composite shells with at least one orthotropic layer
- Material law COMPSH (25) with orthotropic elasticity, two plasticity models and brittle tensile failure,
- Material law CHANG (15) with orthotropic elasticity, fully coupled plasticity and failure models.
These laws are described here. The description of elastic-plastic orthotropic composite laws for solids is presented in the next section.
Tensile Behavior
- Tensile failure strain in direction 1
- Maximum strain in direction 1
- Tensile failure strain in direction 2
- Maximum strain in direction 2
- dmax
- Maximum damage (residual stiffness after failure)
Delamination
The delamination equations are:
Where, is the delamination damage factor. The damage evolution law is linear with respect to the shear strain.
Let then:
for =1 ⇒
Plastic Behavior
The plasticity model is based on the Tsai-Wu criterion 1 which enable to model the yield and failure phases.
Where,
- Tension in direction 1 of orthotropy
- Tension in direction 2 of orthotropy
- Compression in direction 1 of orthotropy
- Compression in direction 2 of orthotropy
- Compression in direction 12 of orthotropy
- Tension in direction 12 of orthotropy
- : plastic admissible state
- : plastically inadmissible stresses
If , the stresses must be projected on the yield surface to satisfy the flow rule. is compared to a maximum value varying in function of the plastic work during work hardening phase:
- Hardening parameter
- Hardening exponent
Failure Behavior
- plastic work limit ,
- maximum value of yield function
- If for one layer,
- If for all layers,
- If or tensile failure in direction 1 for each layer,
- If or tensile failure in direction 2 for each layer,
- If or tensile failure in directions 1 and 2 for each layer,
- If or tensile failure in direction 1 for all layers,
- If or tensile failure in direction 2 for all layers,
- If or tensile failure in directions 1 and 2 for each layer.
In practice, the use of brittle failure model allows to estimate correctly the physical behavior of a large rang of composites. But on the other hand, some numerical oscillations may be generated due to the high sensibility of the model. In this case, the introduction of an artificial material viscosity is recommended to stabilize results. In addition, in brittle failure model, only tension stresses are considered in cracking procedure.
The ductile failure model allows plasticity to absorb energy during a large deformation phase. Therefore, the model is numerically more stable. This is represented by CRASURV model in Radioss. The model makes also possible to take into account the failure in tension, compression and shear directions.
Strain Rate Effect
The strain rate is taken into account within the modification of Plastic Behavior, Equation 13 which acts through a scale factor:
- Plastic work
- Reference plastic work
- Plastic hardening parameter
- Plastic hardening exponent
- Strain rate coefficient (equal to zero for static loading)
CRASURV Model
The CRASURV model is an improved version of the former law based on the standard Tsai-Wu criteria. The main changes concern the expression of the yield surface before plastification and during work hardening. First, in CRASURV model the coefficient in Plastic Behavior, Equation 5 depends only on one input parameter:
With
Another modification concerns the parameters in Plastic Behavior, Equation 5 which are expressed now in function of plastic work and plastic work rate as in Strain Rate Effect, Equation 14:
With
( =12)
( =12)
And
And
Chang Chang Model
Chang-Chang law 2, 3 incorporated in Radioss is a combination of the standard Tsai-Wu elastic-plastic law and a modified Chang-Chang failure criteria. 4 The affects of damage are taken into account by decreasing stress components using a relaxation technique to avoid numerical instabilities.
- Longitudinal tensile strength
- Transverse tensile strength
- Shear strength
- Longitudinal compressive strength
- Transverse compressive strength
- Shear scaling factor
Where, is the fiber direction.
- Tensile fiber mode:
- Compressive fiber mode:
- Tensile matrix mode:
- Compressive matrix mode:
If the damage parameter is equal to or greater than 1.0, the stresses are decreased by using an exponential function to avoid numerical instabilities. A relaxation technique is used by gradually decreasing the stress:
With: and
- Time
- Start time of relaxation when the damage criteria are assumed
- Time of dynamic relaxation
is the stress components at the beginning of damage (for matrix cracking ).
