Barlat's 3- parameter plasticity model is developed in F.
Barlat, J. Lian 1 for modeling of sheet under plane stress assumption with
an anisotropic plasticity model. The anisotropic yield stress criterion for plane stress is
defined as:
Where,
is the yield stress,
and
are anisotropic material constants,
exponent and
and
are defined by:
Where,
and
are additional anisotropic material constants. All anisotropic
material constants, except for
which is obtained implicitly, are determined from Barlat width
to thickness strain ratio
The width to thickness ratio for any angle
can be calculated: 1
Where,
is the uniaxial tension in the
direction. Let
= 45°,
Equation 4 gives an equation from which the anisotropy
parameter
can be computed implicitly by using an iterative
procedure:
Note: Barlat's law reduces to Hill's law when using
=2
1 Barlat F. and Lian J.,
Plastic behavior and stretchability of sheet
metals, Part I: A yield function for orthotropic sheets under plane stress
conditions, International Journal of Plasticity, Vol. 5, pp. 51-66,
1989.
