An airbag is defined as a monitored volume. A monitored volume is defined as having
one or more 3 or 4 node shell property sets.
The defined surface must be closed (the normal to shell elements must be all oriented
outward, as shown in Figure 1. The shell normal must be oriented outside the volume. It
is possible to reverse the shell normals for a given property set (by entering a
negative property number). Dummy properties (/PROP/TYPE0) and
materials (/MAT/TYPE0) can be used.Figure 1. Tire Model: Volume Closed
There are five types of MONITORED VOLUME:
AREA Type: volume and surface output (post processing option, no pressure)
PRES Type: user function defining pressure versus relative volume
GAS Type: adiabatic pressure volume relation. with
AIRBAG Type: Single airbag
COMMU1 Type: Chambered, communicating, folded airbag (airbag with
communications)
Same basic equations:
Typical use of monitored volume is for tire, fuel tank, airbag.
For tire use PRES or GAS type monitored volume.
For fuel tank use PRES or GAS type monitored volume.
For simple unfolded airbag use AIRBAG type monitored volume.
For chambered airbag use two ore more COMMU1 type monitored volumes.
For folded airbag use a set of COMMU1 type monitored volumes.
