In addition to the possibility to define user's material failure models, Radioss integrates several failure models. These models use generally a
global notion of cumulative damage to compute failure. They are mostly independent to
constitutive law and the hardening model and can be linked to several available material
laws. A compatibility table is given in the Radioss
Reference Guide. Table 1 provides a brief description of available
models.
Table 1. Failure Model Description
Failure Model
BIQUAD
Strain failure model
Direct input on effective plastic
strain to failure
CHANG
Chang-Chang model
Failure criteria for
composites
CONNECT
Failure
Normal and Tangential failure
model
EMC
Extended Mohr Coulomb failure
model
Failure dependent on effective
plastic strain
ENERGY
Energy isotrop
Energy density
FABRIC
Traction
Strain failure
FLD
Forming limit diagram
Introduction of the experimental
failure data in the simulation
Strain based Ductile Failure Model:
Hosford-Coulomb with Domain of Shell-to-Solid Equivalence
JOHNSON
Ductile failure model
Cumulative damage law based on the
plastic strain accumulation
LAD_DAMA
Composite delamination
Ladeveze delamination model
NXT
NXT failure criteria
Similar to FLD, but based on
stresses
PUCK
Composite model
Puck model
SNCONNECT
Failure
Failure criteria for plastic
strain
SPALLING
Ductile + Spalling
Johnson-Cook failure model with
Spalling effect
TAB1
Based on damage accumulation using
user-defined functions
TBUTCHER
Failure due to fatigue
Fracture appears when time
integration of a stress expression becomes true
TENSSTRAIN
Traction
Strain failure
WIERZBICKI
Ductile material
3D failure model for solid and
shells
WILKINS
Ductile Failure model
Johnson-Cook Failure Model
High-rate tests in both compression and tension using the Hopkinson bar generally
demonstrate the stress-strain response is highly isotropic for a large scale of metallic
materials. The Johnson-Cook model is very popular as it includes a simple form of the
constitutive equations. In addition, it also has a cumulative damage law that can be
accesses failure:
with:
Where is the increment of plastic strain during a loading increment, the normalized mean stress and the parameters the material constants. Failure is assumed to occur when =1.
Wilkins Failure Criteria
An early continuum model for void nucleation is presented in 1. The model proposes that the decohesion
(failure) stress is a critical combination of the hydrostatic stress and the equivalent von Mises stress :
In a similar approach, a failure criteria based on a cumulative equivalent plastic strain
was proposed by Wilkins. Two weight functions are introduced to control the combination of
damage due to the hydrostatic and deviatoric loading components. The failure is assumed when
the cumulative reaches a critical value . The cumulative damage is obtained by:
Where,
Where,
An increment of the equivalent plastic strain
Hydrostatic pressure weighting factor
Deviatoric weighting factor
Deviatoric principal stresses
a, and
The material constants
Tuler-Butcher Failure
Criteria
A solid may break owning to fatigue due to Tuler-Butcher criteria: 2
Where,
Fracture stress
Maximum principal stress
Material constant
Time when solid cracks
Another material constant, called damage integral
Forming Limit Diagram for Failure
(FLD)
In this method the failure zone is defined in the plane of principal strains (Figure 1). The method usable for shell elements allows
introducing the experimental results in the simulation.Figure 1. Generic Forming Limit Diagram (FLD)
Spalling with Johnson-Cook Failure
Model
In this model, the Johnson-Cook failure model is combined to a Spalling model where you
take into account the spall of the material when the pressure achieves a minimum value Pmin. The deviatoric stresses are set to zero for compressive pressure. If the hydrostatic
tension is computed, then the pressure is set to zero. The failure equations are the same as
in Johnson-Cook model.
Bao-Xue Wierzbicki Failure
Model
Bao-Xue-Wierzbicki model 5 represents a 3D fracture criterion which can
be expressed by:
Where, , , , , and are the material constants, is the hardening parameter and and are defined as:
for solids:
If
Imoy=0:
If
Imoy=1:
for shells:
Where,
Hydrostatic stress
The von Mises stress
Third invariant of principal deviatoric stresses
Figure 2. Graphical Representation of Bao-Xue-Wierzbicki Failure Criteria
Strain Failure Model
This failure model can be compared to the damage model in LAW27. When the principal tension
strain reaches , a damage factor is applied to reduce the stress, as shown in Figure 3. The element is ruptured when =1. In addition, the maximum strains and may depend on the strain rate by defining a scale
function.Figure 3. Strain Failure Model
Energy Density Failure Model
When the energy per unit volume achieves the value , then the damage factor is introduced to reduce the stress. For the limit value , the element is ruptured. In addition, the energy values and may depend on the strain rate by defining a scale
function.Figure 4. Strain Failure Model
XFEM Crack Initialization Failure
Model
This failure model is available for Shell only.
In /FAIL/TBUTCHER, the failure mode criteria are written as:
For ductile materials, the cumulative damage parameter is:
Where,
Fracture stress
Material constant
Time when shell cracks for initiation of a new crack within the structure
Another material constant called damage integral
For brittle materials, the damage parameter is:
1Argon A.S., J. Im, and Safoglu R., Cavity formation from inclusions
in ductile fracture, Metallurgical Transactions, Vol. 6A, pp. 825-837,
1975.
2Tuler F.R. and Butcher B.M., A criteria for time dependence of
dynamic fracture, International Journal of Fracture Mechanics, Vol. 4,
N°4, 1968.
3Hashin, Z. and Rotem, A., A Fatigue Criterion for Fiber
Reinforced Materials, Journal of Composite Materials, Vol. 7, 1973, pp.
448-464. 9.
4Hashin, Z., Failure Criteria for Unidirectional Fiber
Composites, Journal of Applied Mechanics, Vol.
47, 1980, pp. 329-334.
5Wierzbicki T., From crash worthiness to fracture; Ten years of
research at MIT, International Radioss
User's Conference, Nice, June 2006.
