/MAT/LAW114 (SPR_SEATBELT)
Block Format Keyword This spring material is designed for 1D seatbelt elements.
| /MAT/LAW114/mat_ID/unit_ID or /MAT/SPR_SEATBELT/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| Lmin | |||||||||
| K | C | ||||||||
| fct_load | fct_uload | Xscale | Fscale | ||||||
| E | I | J | Fmax | Mmax | |||||
| AS | R | ||||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Density. (Real) |
| Lmin | Minimum length for mass
computation. Default = 1% of average mesh size (Real) |
| K | Linear loading and unloading
stiffness per unit length. Used only if fct_load is not defined. (Real) |
| C | Damping. If not defined, a small amount of damping is automatically applied. 9 (Real) |
| fct_load | Function identifier defining
loading force versus engineering strain
. (Integer) |
| fct_uload | Function identifier defining
unloading force versus engineering strain
. Not used when element is inside slipring or retractors. (Integer) |
| Xscale | Scale factor for
for fct_load and
fct_uload. Default = 1.0 (Real) |
| Fscale | Scale factor for
for fct_load
and fct_uload. Default = 1.0 (Real) |
| E | Young's modulus for compression and
bending. (Real) |
| I | Area moment of inertia
bending. (Real) |
| J | Area moment of inertia
torsion. (Real) |
| Fmax | Maximum force for shear and
compression. (Real) |
| Mmax | Maximum moment for bending and
torsion. (Real) |
| AS | Shear area. (Real) |
| R | Scaling factor for
inertia. Default = 1.0 (Real) |
Example (Seatbelt)
#RADIOSS STARTER
/UNIT/1
Seatbelt
Mg mm s
/MAT/SPR_SEATBELT/1/1
Seatbelt
# Density Lmin
1E-6 0
# KTens CTens
10000 1.1
# fct_load fct_uload Xscale Fscale
0 0 0 0
# E I J FMAX MMAX
0 0 0 0 0
# AS R
0 0
#ENDDATA
/END
- The tension behavior can be defined as linear elastic if K > 0 and fct_load = 0.
- Loading curve (fct_load > 0) is used both for loading and unloading when unloading curve is not defined (fct_uload = 0).
- By default, there is no compression, so function fct_load and fct_uload must be input only for positive strain.
- The behavior in compression can be defined with Young's modulus (E), in that case the behavior can only be perfectly plastic, maximum force being defined by Fmax.
- Bending and torsion behavior are also defined using Young's modulus, area and area of inertia. The behavior is perfectly plastic.
- When the seatbelt element is inside a retractor or a slipring, unloading curve is not used.
- Damping is not applied when the element is inside a slipring and retractor.
- Minimum length is used only in case of sliprings (/SLIPRING/*) and retractors (/RETRACTOR/*) to prevent stiffness becoming infinite.
- It is recommended to use damping for seatbelts. If C = 0, a small amount of critical damping is automatically applied.
