/PROP/TYPE36 (PREDIT)
Block Format Keyword Describes the predit property set. This is a beam-like spring element for spot welds modelization.
/PROP/TYPE36/prop_ID/unit_ID or /PROP/PREDIT/prop_ID/unit_ID | |||||||||
prop_title | |||||||||
Iutyp |
If Iutyp = 1
Skew_ID | prop_ID1 | prop_ID2 | |||||||
Xk |
If Iutyp = 2
mat_ID | |||||||||
Area | IXX | IYY | IZZ | Ray |
Definition
prop_ID | Property
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
prop_title | Property
Iutyp | Property type flag.
(Integer) |
Skew_ID | Skew
identifier (Integer) |
prop_ID1 | First property
prop_ID2 | Second property
Xk | Stiffness for
interface (Real) |
mat_ID | Material
Area | Area (Real) |
IXX | Torsion section inertia
IXX. (Real) |
IYY | Bending section inertia
IYY. (Real) |
IZZ | Bending section inertia
IZZ. (Real) |
Ray | Radius.
(Real) |
Example (Pretensioner)
#RADIOSS STARTER
#- 1. LOCAL_UNIT_SYSTEm:
/UNIT/2
unit for prop
# MUNIT LUNIT TUNIT
kg m s
/PROP/SPR_PRE/11/2
PRETENSIONNER
# M sensor_ID Ilock
.05 1 0
# Stif0 F1 D1 E1 Stif1
100000 0 .25 0 0
#funct_ID1 funct_ID2
1 0
/SENSOR/TIME/1
pretentionner
# Tdelay
0.1
/FUNCT/1
Loading force function vs displacement after sensor activation
# X Y
-1 0
-.1 95
0 100
#ENDDATA
- The PREDIT type 2 is only used with Predit Material (/MAT/LAW54 (PREDIT)).
- A PREDIT type 2 must be reference by a PREDIT type 1: a spring cannot be associated to a PREDIT type 1 only.
- A PREDIT property type 1 can reference two PREDIT property type 2.
