| prop_ID |
Property
identifier. (Integer, maximum 10 digits) |
| unit_ID |
(Optional) Unit identifier. (Integer,
| prop_title |
Property
title. (Character, maximum 100 characters) |
| Mass |
Mass. (Real) |
| I |
Inertia. (Real) |
| Skew_ID |
Skew system identifier.
1 (Integer) |
| sens_ID |
Sensor
identifier. (Integer) |
| Isflag |
Sensor flag. 6
- = 0
- Spring element activated when sens_ID activates and cannot be deactivated.
- = 1
- Spring element deactivated when sens_ID activates and cannot be activated.
- = 2
- Spring elements are activated, or deactivated state
matches the sensor state and can switch back and forth.
The spring initial length (
) is based the spring
length at the activation time.
(Integer) |
| Ifail |
Failure criteria.
- = 0
- Uni-directional criteria.
- = 1
- Multi-directional criteria.
(Integer) |
| Ifail2 |
Failure model flag.
- = 0 (Default)
- Displacement (or rotation) criteria.
- = 1
- Force (or moment) criteria.
- = 3
- Internal energy criteria.
(Integer) |
| Iequil |
Equilibrium flag. 4
- = 0
- No equilibrium.
- = 1
- Force and moment equilibrium.
(Integer) |
| Ki |
If
fct_ID1i =
0: Linear loading and unloading stiffness. If
fct_ID1i ≠
0: Only used as unloading stiffness for
elasto-plastic springs.
= 1, 2, 3 are translation
DOF.
= 4, 5, 6 are rotation
DOF. (Real) |
if
= 1, 2, 3
if
= 4, 5, 6 |
| Ci |
Damping. 1
DOF.
DOF. (Real) |
if
= 1, 2, 3
if
= 4, 5, 6 |
| Ai |
Nonlinear stiffness
function scale factor.
DOF.
DOF. Default = 1.0 (Real) |
if
= 1, 2, 3
if
= 4, 5, 6 |
| Bi |
Scale factor for
logarithmic rate effects.
DOF.
DOF. Default = 0.0 (Real) |
if
= 1, 2, 3
if
= 4, 5, 6 |
| Di |
Scale factor for
DOF.
if
= 1, 2, 3
if
= 4, 5, 6 |
| fct_ID1i |
Function identifier
defining nonlinear stiffness
. 5
- = 0
- Linear spring with stiffness K.
If
Hi=4:
Function defines upper yield curve.
DOF.
DOF. (Integer) |
| Hi |
Spring Hardening flag for
nonlinear spring.
- = 0
- Elastic spring.
- = 1
- Nonlinear elasto-plastic spring with isotropic
hardening.
- = 2
- Nonlinear elasto-plastic spring with uncoupled
hardening.
- = 4
- Nonlinear elastic plastic spring with kinematic
hardening.
- = 5
- Nonlinear elasto-plastic spring with nonlinear
unloading.
- = 6
- Nonlinear elasto-plastic spring with isotropic hardening
and nonlinear unloading.
- = 7
- Nonlinear elastic plastic spring with elastic
hysteresis.
DOF.
DOF. (Integer) |
| fct_ID2i |
Function identifier
defining force or moment as a function of spring velocity,
DOF.
DOF. (Integer) |
| fct_ID3i |
Function identifier. If
Hi
=4: Defines lower yield curve. If
Hi
=5: Defines residual displacement or
rotation versus maximum displacement or rotation. If
Hi
=6: Defines nonlinear unloading
curve. If
Hi
=7: Defines nonlinear unloading curve.
DOF.
DOF. (Integer) |
| fct_ID4i |
Function identifier for
nonlinear damping,
DOF.
DOF. (Integer) |
Negative translation
failure limit.
DOF. Default = -1030 (Real) |
| If
Ifail2 =
0 or 1: Failure
displacement. |
| If
Ifail2 =
2: Failure force. |
| If
Ifail2 =
3: Failure internal energy. |
Negative rotational
failure limit.
| If
Ifail2 =
0, 1: Failure
rotation. |
| If
Ifail2 =
2: Failure moment. |
| If
Ifail2 =
Positive translation
failure limit.
| If
Ifail2 =
0 or 1: Failure
displacement. |
| If
Ifail2 =
2: Failure force. |
| If
Ifail2 =
Positive rotational
failure limit.
| If
Ifail2 =
0 or 1: Failure
rotation. |
| If
Ifail2 =
| If
Ifail2 =
| Fi |
Abscissa scale factor for
the damping functions for the
and
DOF.
if
= 1, 2, 3
if
= 4, 5, 6 |
| Ei |
Ordinate scale factor for
DOF.
DOF. (Real) |
if
= 1, 2, 3
if
= 4, 5, 6 |
| Ascalei |
the stiffness function
DOF.
if
= 1, 2, 3
if
= 4, 5, 6 |
| Hscalei |
DOF.
if
= 1, 2, 3
if
= 4, 5, 6 |
