/MAT/LAW134 (VISCOUS_FOAM)
Block Format Keyword This material law represents the open-celled urethane foam used for the ribs of a Euro-SID side impact dummy. Only available for solid.
| /MAT/LAW134/mat_ID/unit_ID or /MAT/VISCOUS_FOAM/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E1 | N1 | ||||||||
| E2 | V2 | N2 | |||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| E1 | Young’s
modulus. (Real) |
| N1 | Exponent in power law for Young’s
modulus. Default = 1.0 (Real) |
| Poisson ratio. (Real) |
| E2 | Elastic modulus for
viscosity. (Real) |
| V2 | Viscous
coefficient. (Real) |
| N2 | Exponent in power law for
viscosity. (Real) |
Example (Foam)
#RADIOSS STARTER
/UNIT/1
Unit for mat
Mg mm s
/MAT/VISCOUS_FOAM/1
Foam
# Rho_I
1.00000000000000E-09
# E1 N1 PR
1.0 4.0 0.05
# E2 V2 N2
1000.0 0.015 0.2
#ENDDATA
/END
- The model consists of nonlinear elastic stiffness and viscous damper
in parallel (Figure 1). Elastic stiffness is intended to limit total
deformation while the viscosity absorbs energy.
Figure 1. Model scheme
- Both
and
give the nonlinear material behavior
with:Where, is the volume ratio.
- Actual volume
- Initial volume
