/MAT/LAW75 (POROUS)
Block Format Keyword Describes the P- α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ porous material model. This material describes ductile Porous material with Herrmann model. It only works with 8-node brick element and is not compatible with ALE.
/MAT/LAW75/mat_ID/unit_ID or /MAT/POROUS/mat_ID/unit_ID
mat_title
ρ i
E υ
mat_IDs Iflag1 Iflag2 itemax
PE Ps n
tol
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density for porous material.
(Real)
[ kg m 3 ]
E Young's modulus.
(Real)
[ Pa ]
υ Poisson's ratio.
(Real)
mat_IDs Material identifier of the solid (fully compacted) material.
(Integer)
Iflag1 Pressure formulation flag.
= 1 (Default)
Herrmann. 1
= 2
Modified Herrmann. 2
(Integer)
Iflag2 Deviatoric stresses formulation flag.
= 1 (Default)
Hydrodynamic
= 2
Elastic
(Integer)
itemax Maximum number of iterations on a calculation.
Default = 5 (Integer)
PE Elastic compact pressure (elastic limit). 3
(Real)
[ Pa ]
Ps Solid (matrix) compact pressure. 3
(Real)
[ Pa ]
n Exponent used for fitting the experiment data. 3
Default = 2 (Real)
tol Convergence tolerance on a calculation.
| Δ α | α < t o l
Default = 10-8 (Real)
Example (Porous Soil)
#-  2. LOCAL_UNIT_SYSTEm:
/UNIT/1
unit for mat
#              MUNIT               LUNIT               TUNIT
                   g                  cm                 mus
#-  1. MATERIALS:
/MAT/LAW75/1/1
porous soil
#              RHO_I
                 1.7
#                 E                   NU
                   3                  .3
#  MAT_IDs    IFLAG1    IFLAG2    ITEMAX
         2         1         2         0
#                PE                   PS                   N
                 .01                 .05                   0
#               TOL
                   0
/MAT/HYD_JCOOK/2/1
soil
#              RHO_I               RHO_O
          1.76000004                   0
#                  E                  nu
           3.5999999          .300000012
#                  A                   B                   n              epsmax              sigmax
               10000                   0                   0                   0                   0
#               Pmin
                   0
#                  C           EPS_DOT_0                   M               Tmelt                Tmax
                   0                   0                   0                   0                   0
#              RHOCP                                                       Troom
                   0                                                           0
/EOS/POLYNOMIAL/2/1
EOS for soil
#                 C0                  C1                  C2                  C3
                   0          2.81999993                   2               -1.37
#                 C4                  C5                  E0                 Psh               RHO_0
          1.53999996          1.53999996                   0                   0                   0
#enddata
  1. The porosity α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ is defined as:
    α = ρ s ρ
    Note that α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ ≥ 1 ( ρ s ≥ ρ )
    Where,
    ρ s
    Density of the solid (full compacted matrix) material
    ρ
    Density of the porous material
  2. If the EOS of the solid (matrix) material is:
    P = f ( ρ s , e )
    Then the EOS of the porous material is:
    P = f ( α ρ , e )
    for Herrmann formulation
    P = 1 α f ( α ρ , e )
    for modified Herrmann formulation
    Where, ( e ) is the internal energy per unit mass. It is same in porous material and in the solid (matrix) material.
  3. If P < P E the behavior is elastic, and if P > P E describes plastic region.
    In the elastic region, the change of porosity α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ with pressure P is reversible.
    In the plastic region, the porosity α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ is assumed to depend on pressure as described below:
    α = 1 + ( α P − 1 ) [ P S − P P S − P E ] n
    Where,
    α P
    Porosity where pressure reach the elastic compact pressure P E
    α = 1
    Pressure reaches the solid (matrix) compact pressure P S
    α 0
    Initial porosity
    mat_law75_porosity
1 "Constitutive equation for the dynamic compaction of ductile porous materials", Herrmann W., J. Applied Physics 40, 1969
2 "Static and dynamic pore collapse relations for ductile porous materials", Carroll M.M., Holt A.C., J. Applied Physics 43, 1972
