/MAT/LAW18 (THERM)
Block Format Keyword This law describes thermal material.
/MAT/LAW18/mat_ID or /MAT/THERM/mat_ID | |||||||||
mat_title | |||||||||
A | B | ||||||||
fct_IDT | T0 | FscaleT | |||||||
fct_IDsph | fct_IDas | Fscalesph | FscaleE | FscaleK |
Definition
mat_ID | Material
mat_title | Material
Initial
density (Real) |
Reference density used in
E.O.S (equation of state). Default = (Real) |
Specific
heat (Real) |
A | Conductivity coefficient
A (Real) |
B | Conductivity coefficient
B (Real) |
fct_IDT | Function
f(t) identifier for T. 9
(Integer) |
T0 | Initial
temperature. Default = 300K (Real) |
FscaleT | Time scale
factor. (Real) |
fct_IDsph | Function g(T, E)
identifier for temperature versus energy. 7 (Integer) |
fct_IDas | Function h(k, T)
identifier for conductivity versus
temperature. (Integer) |
Fscalesph | Temperature scale
factor. (Real) |
FscaleE | Energy scale
factor. (Real) |
FscaleK | Conductivity scale
factor. (Real) |
- This material can be used:
- as purely thermal material (only Line 4 is read)
- as boundaries conditions (temperature or flux) (use Line 5)
- The
(thermal conductivity) is computed
as:
(1) - The
(thermal diffusivity) is computed as:
(2) Where, is the heat capacity at constant pressure.
- The (thermal conductivity) is given by curve .
- The (thermal diffusivity) is computed with curve fct_IDsph with, .
- Function g(T, E) is similar to
the following curve:
- If
fct_IDsph ≠
0,
(3) Where, is the function of fct_IDsph.
- If
fct_IDsph =
0,
(4) with
- If
fct_IDT ≠
0,
(5) with ; .
- If
fct_IDas ≠ 0,
(6) ;
Where, is the function of fct_IDas.
