/MAT/LAW163 (CRUSHABLE_FOAM)
Block Format Keyword This law models strain rate dependent crushable foam material. This law is applicable only for solid elements and is typically used to model low density, closed cell polyurethane foams.
/MAT/LAW163/mat_ID/unit_ID or /MAT/CRUSHABLE_FOAM/mat_ID/unit_ID
mat_title
ρ i
E ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ TSC DAMP NCYCLE
Tab_ID Epsd_ref Fscale SRC_LIMIT NRS
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier.
mat_title Material title.
ρ i Initial density.
(Real)
E Young's modulus.
(Real)
[ Pa ]
ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ Poisson's ratio.
Default = 0.0 (Real)
TSC Tensile stress cutoff.
Default = 1020 (Real)
[ Pa ]
DAMP Damping coefficient (recommended between 0.05 and 0.5).
(Real)
NCYCLE Number of cycles for volumetric strain rate filtering.
Default = 12 (Integer)
Tab_ID Yield stress table identifier versus volumetric strain and volumetric strain rate.
(Integer)
Epsd_ref Scale factor for strain rate in Tab_ID (also called reference strain rate).
Default = 1.0 (Real)
[ 1 s ]
Fscale Scale factor for stress in Tab_ID.
[ Pa ]
SRC_LIMIT Strain rate change limit.
Default 1020 (Real)
[ 1 s ]
NRS Strain rate dependency type flag.
= 0 (Default)
True volumetric strain rate.
= 1
Engineering volumetric strain rate.
(Integer)
Example (Crushable Foam)
/UNIT/1
unit_Mg_mm_s
                  Mg                  mm                   s
/MAT/LAW163/1/1
Crushable foam
#              RHO_I
               1E-10
#                  E                  NU                 TSC                DAMP              NCYCLE
                  10                 0.1                 5.0                0.05                   1
#             TAB_ID            EPSD_REF              FSCALE           SRC_LIMIT                 NRS
                   1        0
/TABLE/1/1
Stress vs volumetric strain
         1
#                  X                   Y
                   0                   0
               0.001         0.324440816
               0.002         0.432139501
               0.003         0.511748811
               0.004         0.577416977
               0.005         0.634416215
               0.006         0.685381975
               0.007         0.731849674
               0.008         0.774804109
               0.009         0.814920344
                0.01         0.852684325
                0.02         1.153108519
                0.03         1.380738481
                0.04         1.572021977
                0.05         1.740600504
                0.06         1.893316035
                0.07         2.034165965
                0.08         2.165720524
                0.09          2.28974548
                 0.1         2.407514491
                0.11         2.519981277
                0.12         2.627881481
                0.13         2.731796386
                0.14          2.83219458
                0.15         2.929460226
                0.16         3.023912838
                0.17         3.115821497
                0.18         3.205415286
                0.19         3.292891111
                 0.2         3.378419669
                0.21         3.462150065
                0.22         3.544213433
                0.23         3.624725821
                0.24         3.703790499
                0.25         3.781499843
                0.26         3.857936868
                0.27           3.9331765
                0.28         4.007286637
                0.29          4.08032903
                 0.3         4.152360035
                0.31         4.223431248
                0.32         4.293590044
                0.33          4.36288005
                0.34         4.431341538
                0.35         4.499011781
                0.36          4.56592535
                0.37         4.632114386
                0.38         4.697608826
                0.39         4.762436612
                 0.4         4.826623873
                0.41         4.890195086
                0.42         4.953173221
                0.43         5.015579868
                0.44         5.077435358
                0.45          5.13875887
                0.46         5.199568528
                0.47         5.259881493
                0.48         5.319714057
                0.49         5.379081726
                 0.5         5.437999308
                0.51         5.496481009
                0.52         5.554540531
                0.53         5.612191185
                0.54         5.669446026
                0.55          5.72631801
                0.56         5.782820188
                0.57         5.838965953
                0.58         5.894769339
                0.59         5.950245415
                 0.6         6.005410776
                0.61         6.060284172
                0.62         6.114887315
                0.63         6.169245897
                0.64         6.223390893
                0.65         6.277360212
                0.66          6.33120078
                0.67         6.384971174
                0.68         6.438744927
                0.69         6.492614676
                 0.7         6.546697342
                0.71         6.601140582
                0.72         6.656130808
                0.73         6.711903108
                0.74         6.768753501
                0.75         6.827054026
                0.76         6.887271255
                0.77         6.949988973
                0.78         7.015935864
                0.79         7.086019231
                 0.8         7.161365954
                0.81         7.243372132
                0.82         7.333763083
                0.83         7.434665711
                0.84         7.548695574
                0.85         7.679061418
                0.86         7.829690392
                0.87         8.005377719
                0.88         8.211965236
                0.89         8.456553919
                 0.9         8.747756361
                0.91         9.095996146
                0.92         9.513862121
                0.93         10.01652688
                0.94         10.62224018
                0.95         11.35290965
                0.96         12.23478312
                0.97         13.29924886
                0.98         14.58377261
                0.99         16.13299299
                   1                  18
#ENDDATA
  1. The material law is based on the volumetric strain denoted γ and computed with:
    γ = 1 − ρ 0 ρ MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdCMaey ypa0JaaGymaiabgkHiTmaalaaabaGaeqyWdi3aaSbaaSqaaiaaicda aeqaaaGcbaGaeqyWdihaaaaa@3ECD@
    Where,
    ρ 0
    Initial density
    ρ
    Current density
    Such definition of volumetric strain implies that γ > 0 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdCMaey Opa4JaaGimaaaa@3960@ in compression, and γ < 0 MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4SdCMaey ipaWJaaGimaaaa@395D@ in tension.
  2. The elastic behavior considers a Young's modulus denoted E and a Poisson’s ratio denoted ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ (considered to be close or equal to zero). Note that the Young's modulus defined in the input may be overwritten. The maximum slope of stress versus volumetric strain tabulated evolution is computed and retained for elastic stiffness to ensure stability. Using E and ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ , the classical Hook isotropic elasticity is considered as trial stress tensor.
    σ n + 1 r = σ n + ℂ Δ ε n + 1 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbeqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4WdmaaDa aaleaacaWHUbGaaC4kaiaahgdaaeaacaWH0bGaaCOCaaaakiabg2da 9iaabo8adaWgaaWcbaGaaCOBaaqabaGccqGHRaWkcqWIceYOcaWHuo GaaCyTdmaaBaaaleaacaWHUbGaaC4kaiaahgdaaeqaaaaa@467C@
    For foams, the Poisson’s ratio ν MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyVd4gaaa@37AF@ is often assumed to be zero. In that case, the equation above becomes:
    σ n + 1 t r = σ n + E Δ ε n + 1 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4WdmaaDa aaleaacaWHUbGaaC4kaiaahgdaaeaacaWH0bGaaCOCaaaakiabg2da 9iaaho8adaWgaaWcbaGaaCOBaaqabaGccqGHRaWkcaWGfbGaaCiLdi aahw7adaWgaaWcbaGaaCOBaiaahUcacaWHXaaabeaaaaa@45FA@
  3. The nonlinear behavior is assumed to be unsymmetric, considering a tensile and a compressive case. To do so, the scaling of trial stress tensor is based on the modification of its principal stresses. Once the three principal stresses are obtained, each one can be scaled depending on its sign as:
    σ i = 1 , 3 = − σ t a b i f σ i ≤ − σ t a b σ T S C i f σ i ≥ σ T S C MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMgacqGH9aqpcaaIXaGaaiilaiaaiodaaeqaaOGaeyyp a0ZaaiqaaeaafaqabeGadaaabaGaeyOeI0YaaqWaaeaacqaHdpWCda WgaaWcbaGaamiDaiaadggacaWGIbaabeaaaOGaay5bSlaawIa7aaqa aiaadMgacaWGMbaabaGaeq4Wdm3aaSbaaSqaaiaadMgaaeqaaOGaey izImQaeyOeI0YaaqWaaeaacqaHdpWCdaWgaaWcbaGaamiDaiaadgga caWGIbaabeaaaOGaay5bSlaawIa7aaqaaiabeo8aZnaaBaaaleaaca WGubGaam4uaiaadoeaaeqaaaGcbaGaamyAaiaadAgaaeaacqaHdpWC daWgaaWcbaGaamyAaaqabaGccqGHLjYScqaHdpWCdaWgaaWcbaGaam ivaiaadofacaWGdbaabeaaaaaakiaawUhaaaaa@65BA@
    Thus, negative principal stresses are scaled using the tabulated stress versus volumetric strain (and volumetric strain rate if defined), and positive principal stresses are scaled to the constant cutoff value.
    Note: The tensile cutoff stress is not submitted to strain rate dependency. Also, the tabulated scaling stress is only used in compression.
    Afterwards, the modified principal stress tensor is rotated back to the global reference system using principal vectors to obtain the current Cauchy stress tensor.
    σ=P σ p P -1  with  σ p = σ 1 0 0 0 σ 2 0 0 0 σ 3 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbeqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4Wdiabg2 da9iaahcfacaqGdpWaaSbaaSqaaiaahchaaeqaaOGaaCiuamaaCaaa leqabaGaaCylaiaahgdaaaGccaqGGaGaae4DaiaabMgacaqG0bGaae iAaiaabccacaqGGaGaae4WdmaaBaaaleaacaWHWbaabeaakiabg2da 9maadmaabaqbaeqabmWaaaqaaiabeo8aZnaaBaaaleaacaaIXaaabe aaaOqaaiaaicdaaeaacaaIWaaabaGaaGimaaqaaiabeo8aZnaaBaaa leaacaaIYaaabeaaaOqaaiaaicdaaeaacaaIWaaabaGaaGimaaqaai abeo8aZnaaBaaaleaacaaIZaaabeaaaaaakiaawUfacaGLDbaaaaa@55CB@
  4. To improve the stability of this material law, a viscous damping can be used. Viscous over-stresses are then added to the computed Cauchy stress tensor. Their computation is governed by the equation:
    Δ σ i =a ε ˙ i − ε ˙ m 1+ν + ε ˙ m 1−2ν  with  ε ˙ m = Tr ε ˙ 3  if i=1,2,3 Δ σ i = a ε ˙ i 2 1+ν  if  i=4,5,6 With a= c s ρ μ damp L e 1+γ    MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacqqHuo arcqaHdpWCdaWgaaWcbaGaamyAaaqabaGccqGH9aqpcaWGHbWaaeWa aeaadaWcaaqaaiqbew7aLzaacaWaaSbaaSqaaiaadMgaaeqaaOGaey OeI0IafqyTduMbaiaadaWgaaWcbaGaamyBaaqabaaakeaacaaIXaGa ey4kaSIaeqyVd4gaaiabgUcaRmaalaaabaGafqyTduMbaiaadaWgaa WcbaGaamyBaaqabaaakeaacaaIXaGaeyOeI0IaaGOmaiabe27aUbaa aiaawIcacaGLPaaacaqGGaGaae4DaiaabMgacaqG0bGaaeiAaiaabc cacuaH1oqzgaGaamaaBaaaleaacaWGTbaabeaakiabg2da9maalaaa baGaaeivaiaabkhadaqadaqaaiqahw7agaGaaaGaayjkaiaawMcaaa qaaiaaiodaaaGaaeiiaiaabMgacaqGMbGaaeiiaiaadMgacqGH9aqp caaIXaGaaiilaiaaikdacaGGSaGaaG4maaqaaiabfs5aejabeo8aZn aaBaaaleaacaWGPbaabeaakiabg2da9maalaaabaGaamyyaiqbew7a LzaacaWaaSbaaSqaaiaadMgaaeqaaaGcbaGaaGOmamaabmaabaGaaG ymaiabgUcaRiabe27aUbGaayjkaiaawMcaaaaacaqGGaGaaeyAaiaa bAgacaqGGaGaaeiiaiaadMgacqGH9aqpcaaI0aGaaiilaiaaiwdaca GGSaGaaGOnaaqaaiaabEfacaqGPbGaaeiDaiaabIgacaqGGaGaamyy aiabg2da9maalaaabaGaam4yamaaBaaaleaacaWGZbaabeaakiabeg 8aYjabeY7aTnaaBaaaleaacaWGKbGaamyyaiaad2gacaWGWbaabeaa kiaadYeadaWgaaWcbaGaamyzaaqabaaakeaacaaIXaGaey4kaSIaeq 4SdCgaaaqaaiaabccacaqGGaaaaaa@94E1@
    Where,
    c s MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4yamaaBa aaleaacaWGZbaabeaaaaa@3804@
    Material sound speed
    μ damp MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd02aaS baaSqaaiaadsgacaWGHbGaamyBaiaadchaaeqaaaaa@3B90@
    Damping coefficient defined in the input card
    L e MathType@MTEF@5@5@+= feaahGart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitamaaBa aaleaacaWGLbaabeaaaaa@37DF@
    Element characteristic length
  5. To avoid noisy results due to volumetric strain rate dependency, a low-pass filter can be activated over several cycles defined by you. A default value of 12 cycles is used. The filtered volumetric strain rate is obtained with:
    γ ˙ n+1 filt =α γ ˙ n+1 + 1−α γ ˙ n filt With α= 2π 2π+ N cycle    MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacuaHZo WzgaGaamaaDaaaleaacaWGUbGaey4kaSIaaGymaaqaaiaadAgacaWG PbGaamiBaiaadshaaaGccqGH9aqpcqaHXoqycuaHZoWzgaGaamaaBa aaleaacaWGUbGaey4kaSIaaGymaaqabaGccqGHRaWkdaqadaqaaiaa igdacqGHsislcqaHXoqyaiaawIcacaGLPaaacuaHZoWzgaGaamaaDa aaleaacaWGUbaabaGaamOzaiaadMgacaWGSbGaamiDaaaaaOqaaiaa bEfacaqGPbGaaeiDaiaabIgacaqGGaGaeqySdeMaeyypa0ZaaSaaae aacaaIYaGaeqiWdahabaGaaGOmaiabec8aWjabgUcaRiaad6eadaWg aaWcbaGaam4yaiaadMhacaWGJbGaamiBaiaadwgaaeqaaaaaaOqaai aabccacaqGGaaaaaa@656F@
  6. You can choose the type of the volumetric strain rate dependency defined in the input.
    • If NRS = 0, true volumetric strain rate dependency is used.
      γ ˙ =− V ˙ V =−Tr ε ˙    MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacuaHZo WzgaGaaiabg2da9iabgkHiTmaalaaabaGabmOvayaacaaabaGaamOv aaaacqGH9aqpcqGHsislcaqGubGaaeOCamaabmaabaGafqyTduMbai aaaiaawIcacaGLPaaaaeaacaqGGaGaaeiiaaaaaa@43AE@
    • If NRS = 1, engineering volumetric strain rate dependency is used.
      γ ˙ = − V ˙ V 0    MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGceaqabeaacuaHZo WzgaGaaiabg2da9iabgkHiTmaalaaabaGabmOvayaacaaabaGaamOv amaaBaaaleaacaaIWaaabeaaaaaakeaacaqGGaGaaeiiaaaaaa@3DA6@
