The source code for the C support library (CG32.LIB) is required for the following reasons:
•To enhance the functionality of the C support library.
•To generate executable files to be run on processors other than the ones supported by the object code version of the C support library shipped with Embed. For example, to embed the source code library in a Hitachi chip, you need to recompile and relink the support library using a Hitachi compiler.
The source code for the CG32.LIB support library is a separate product that is not automatically included when you purchase Embed.
