Target Category: Arduino, Delfino, F280x, F281X, Piccolo
Target Sub-Category: ADC
Description: The Analog Input block receives analog data from the ADC peripheral on the embedded target. During simulation, Analog Input produces the data supplied by the corresponding Analog In block.
Note that the block output type is scaled integer and holds fractional values between 0 and 1, where 1 corresponds to a full-scale ADC result regardless of the bits in the ADC converter.
Channel: Indicates the channel number. Click here for Arduino pin mapping.
Title: Indicates the channel title.
Unit: Indicates the unit number. This parameter is available only for devices that support it.
