When the controller algorithm is running on a target and the plant model is running on the host computer, you use a debug diagram to:
•Dynamically adjust parameters in the executable code
•Provide real-time feedback for the controller responses on the host
You can also use the serial monitor in the Arduino IDE to debug code on an Arduino, as demonstrated in the Embed Common Simulation and Code Generation Tasks Tutorial at Altair Community Documentation.
