The Generic MCU Target Interface block is used to generate code that will execute code on an embedded target that is not currently supported by Embed. This block generates skeletal embedded code; that is, static RAM and optimized CPU usage. In most cases, when you use the Generic MCU Config block, you will also need the C Support Library Source Code add-on module.
