A Hotlink is used to interactively control the target from the host computer and to collect real-time data from the target to be presented or stored on the host computer.
•C2000, ARM Cortex M3, and STM32 targets use a JTAG HotLink
•Arduino targets use a serial HotLink
•Linux (AMD64 and Raspberry Pi) targets use an Ethernet or WiFi Hotlink
To use a HotLink, you must encapsulate the controller algorithm in a compound block. It can be handy to label the input and output connectors with unique names.
You can create custom rate functions by configuring specific parameters in the compound block.
