You can control how code is executed on a target by activating parameters in the compound block containing the controller algorithm.
See Also:
Controlling block execution
Copying code from FLASH to RAM
Specifying a local step size and local bounds
Generating code as preemptible background thread
Creating and executing interrupt handlers
