Specifying a local step size and local bounds
The Local Time Step parameter lets you specify a step size larger than the base system step size. It must be an integer multiple of the base step. In addition, choosing a local time step will cause the block to appear with a diagonal striping to indicate the nonstandard timing. When used with the Use Local Bounds parameter, the Local Step Size parameter provides additional control over a multi-rate simulation. For more information, search for Multi-rate Simulation under Help > Contents: Modeling and Simulation.
